60-2 Fidanza flywheel for 951. Made One
Old 04-11-2009, 08:47 PM
95ONE
95ONE's Avatar
Default 60-2 Fidanza flywheel for 951. Made One
Solved my crank signal issue.
Any other available option has failed me. This solves so many problems at once it's ridiculous.
Uses factory sensor, sensor bracket, and location. One reliability problem solved baby! (Pretty much one of only two known)
Edit: Read carefully..This ring is off a 968.... It pops off the flywheel for a 968. It can be machined on like this.. but the optimal way is to make one less deep so as to not have to cut into the pressure plate threads like this one has done.
A ring that won't have to machine into the Aluminum flywheel pressure plate threads is being made. .
It's good to know a good CNC machinist.
Old 04-11-2009, 09:04 PM
jlturpin
jlturpin's Avatar
Very nice work.
Old 04-11-2009, 09:11 PM
theedge
theedge's Avatar
How much for an identical ring?
Old 04-11-2009, 09:30 PM
95ONE
95ONE's Avatar
The ring eats up the CNC bit. So it's not cheap.
This is actually a ring off off a 968 flywheel!!! It just pops off. It's not a good match though. It's too thick and would eat into the pressure plate threads. This is what is in the picture, but a new ring is in the works and will be made to be not as "deep" and will pose no issue for the threads.
This was a prototype. I need one now, and I'm going to use it. But I'm having the newer, better fit 60-2 Steel ring made. My flywheel friction plate is gettig thin, and I will need a newer one soon anyway.
Old 04-11-2009, 09:46 PM
V2Rocket
Rainman
V2Rocket's Avatar
wait did you have him machine you an entirely new crank ring?
Old 04-11-2009, 09:59 PM
95ONE
95ONE's Avatar
That's happening now. the ring in the picture is off a 968 flywheel. Pops off. So to answer your question,...almost.
Old 04-11-2009, 10:02 PM
V2Rocket
Rainman
V2Rocket's Avatar
oh neato.
Old 04-11-2009, 10:04 PM
95ONE
95ONE's Avatar
I kinda can't believe no one has done this before. It seems so simple.
But. I wouldn't have figured it out unless I had bought the 968 motor.
Old 04-11-2009, 10:45 PM
jlturpin
jlturpin's Avatar
944S and S2's both use 60-2 trigger wheels and have a cam sync. I am pretty sure they are built into the S and S2 flywheels though. I never had a 968 flywheel off, so it obviously is not.
Old 04-11-2009, 11:23 PM
95ONE
95ONE's Avatar
Have you tried to pull it off? Screwdriver and hammer. I'm curious. It doesn't look like they are a separate piece. But once you start prying...
Old 04-12-2009, 04:07 AM
theedge
theedge's Avatar
I was thinking about it, but just as getting a 968 Fidanza.... Those are pricey though.
Old 04-12-2009, 04:17 AM
blown 944
blown 944's Avatar
very nice work. at one time I was doing the same thing to be able to use the 951 PP and clutch with the NA starter ring to get a better clutch in that car (different ring gear teeth qty).
Ended up with a centerforce clutch and PP instead, that has seemed to hold up better than some of my other choices in the 951 car
Old 04-12-2009, 10:40 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
968 / S2 flywheels use a smaller diameter pressure plate....
BTW - let me know if you want to make some extra rings....I might just have a use for them!
Old 04-12-2009, 12:45 PM
jlturpin
jlturpin's Avatar
I don't have an S/S2 flywheel here, but I am fairly certain that they were machined/cast in the flywheel.
I had a link but can't seem to find it, the place trigger wheels, using waterjet. I am with Chris, if you are able to get several, I would be interested in one.
Old 04-12-2009, 05:41 PM
95ONE
95ONE's Avatar
Several? LOL. ok. I'll talk to my machinist. I'll PM you guys some time next week.
Quick Reply: 60-2 Fidanza flywheel for 951. Made One
