MAF KIT what to expect
#48
Same here...I'm one of the old ford guys (early 90's) that had to modify the stock pito tube in the MAF to change injectors sizes until they came out with the C&L meters that offered different pito tubes..then came the Pro-M meters that had different calibrations for each injector size...then finally newer software came out that allowed you to reflash the eproms.
As far as the 951 goes I've also been through the evolution of the products with the ARC-2 and ford meter from huntley, APE and pro-M, recent signal converters (mafterburner)...
Things are much easier these days (albeit a bit more expensive but well worth it)........Now we can get 83lb injectors to idle like stock using the stock Motronic boxes. Whoda thunk?
#50
The software, the hardware (chip/board, Wasted Spark system,...) are designed, developed and tested in house.
#51
I think both vendors have there pluses. I can say that not all expensive chips work with other peoples mafs. Trust me I know from experience and dropped a ton of money on the ordeal.
The maf is a great upgrade and helps tremendously with spool, however it makes the car much more finiky, and I for one went back the afm.
#52
Also to help diagnose issues, soon we will offer the Motronic Diagnostic tool (it has its own thread).
#53
John, I agree everything has to be working properly. In my case and several others that I know all was and is working properly, however the maf made the car finiky and caused overly rich and holes in the map. This was not caused by a faulty sensor etc.... I think everyone needs to here the pros and cons of a system and I also feel half my problem was that I was mixing to vendors products.
#54
#56
What to expect with a MAF...tons of fun and a learning experience second to none...who you want to take along with you for that learning experience....my choice.
I have an Autothority MAF and Vitesse controls the rest. And have not had problem one. Talk about smooth.
