I need a clutch
hey tman -
did you opt for a lightened pressure plate? Is that why there are holes?
I am a bit Confused as that is exactly where I would not want one to be lightened.
Did this come that way from spec, or was it otherwise modified?
I am getting ready to pickup a stage3 hybrid spec setup myself, and expect 400 whp on E85.
Greatly appreciate you sharing
I don't think you should have any trouble with 400 whp.
I was running lots of boost and drag radials on a very sticky surface when clutch started slipping.
My clutch only had like 5k miles on it but I did abuse the crap out of it.
This is probably the best setup. The Kep 1 is pretty strong. I think my Kep 2 is pretty heavy.
thanks for the info on your spec - I will chat with them to ensure I do not get a pressure plate with holes machined in the mating surface.
