Intercooler Options
Intercooler Options
Anyone have intercooler upgrade experiences to share -- either end-tank mods, fmic or other replacements? I'm mulling over options and would appreciate hearing from those who've upgraded. Thanks.
The Impaler
It seems like there is plenty of room for an FMIC if you cut part of the bumper bar, but you were asking for experience and I haven't done it yet. Hopefully in the next couple of months.
Ryan,
I believe it was around 25" across (just barely fit between the frame rails) and 4" thick and like 18" tall? Man, I can't remember exactly. You can look at the pictures and take some measurements on your car. The top came just below the top of the bumper bar and it went down as far as the bumper cover. I had to notch the bottom inside of the bumper cover for clearance.
Wow, that should be a complete kit w/ the ducting, oil lines, and everything! Well done!!
My only question. Why make the inlet/outlet on the intercooler bigger than the intercooler pipes? Wouldn't that be a bigger pressure drop as it enters the intercooler and more flow restriction as reenters the smaller i/c pipes?
(I don't know, but I'd like to learn)
EDIT: Were you using a "vented" nose panel?
The Impaler
Also it means if you want to go to 3" IC pipes later you are set
Looks good Aribop -- your craftsmanship is always first rate. Did that start life as SFR parts, or did you build it all from scratch?
My question should be: Why such a thick intercooler?
EDIT: I see the SFR I/C is 23x8x3.5 and should flow 750 cfm at 1.5 psi pressure drop. That's both thicker than I expected and less pressure drop than I expected, but this I/C is WAY bigger.
Tom,
Whatever IC you buy, make sure its a real Spearco core (or Bell). The core makes all the difference. Bell is in TX and they can make a custom IC to your dimensions/specs. Make sure its rated for your HP. Its more money than a Ebay IC but should you do anything else, your wasting your time. You have a nice car and a lot of good parts, don't cut corners on this.
