Options for repainting brakes
I'm working to repaint my brakes. I've gone back and forth between paint and powder coat. The only problem is I don't want to rebuild them right now.
Is it a good idea to have the calipers sand blasted and powder coated since I'm not rebuilding them. Is sand blasting a good idea either way?
I just want to get this thing so I can finally drive it.
yeh i thoink they could be done without being stipped they would see more heat in a hard drive than in the powder coat process .
hey what color ?? I'm considering gold
I used VHT caliper paint, results were good. 2 track days and prob 1500 miles on them, still look new. Just going to wait and see how they hold up. Im a powdercoat ***** so Ill prob go that way if they start to look crappy.
I think this was about 5-6 color coats with 2 coats of clear:
I used the G2 caliper paint system, which has held up well for almost 3 years. It's much better than the VHT paint I used to touch up a nick from a brake pad swap. It was about $30 mailorder.
Hey Man
Don't laugh but I have used Rustoleum canned enamel and a soft brush on 4 sets of calipers so far. All I do is wire brush them and make sure there is no grease and paint them right on the car. I have yet to see any heat or paint damage even on hot runs in the Sierra's. I think high priced caliper paints are fine but why if the el cheapo works and looks just as good. The pic below is after 2 years on the road.
I used Ford Red engine paint the first time. Its starting to peel from getting brake fluid on them. I may go that route again and powder coat them later when they need rebuilding.
I used red VHT paint from Pepboys. I sanded and painted the calipers insitu.
Used the whole can of paint along with a can of VHT clear laquer.
Other than a few scratches and nicks, still looks great after 3 years.
I did add some thinner and used a better softer brush which left hardly any brush marks...there's a few on the back where I got lazy. The brush that comes with the kit is way too coarse.
