Winter project under way. Updated 01/07
#121
Here is a sneak peak at the direction its going. Still. It won't be white. But there will be parts that are. So white is the first color. I still have to do some welding in the interior before I can paint that. Roof is completely molded in. So is the drain rail, now one with the roof.
#124
Now doesn't that look all nice and shiny with it's new coat Bruce! Did you do the paint too?
Those wheels look a nice snug fit too.
#126
This forum is starting to get some real nice builds nowadays compared to like 8 years ago when it was considered pretty cool when a forum member had a MAF system
#127
Thank YOU. Its so nice to see something start to come together. So much work and it's looked like so little.
No.. I didn't paint it. I have a paint and body guy / friend at the shop.
The wheels. well.. I have a spacer coming to make them flush, and the car is going to be lowered another inch and a half.
#128
#130
No pics, but a small Update. I just re-did the harness bar. I cut out the straight bar and bent one that curves back 4". I welded up the gussets and harness guides. The welding didn't come out as pretty as I was hoping for.I guess I'm a little rusty welding upside down with metal in my back, and my face smashed in a corner and no way to adjust TIG voltage. So.. It is what it is I guess. I also removed my passenger foot well bar and re bent a new one to make as a leg /Dry sump tank protecter. I guess I can post a pic of that just for explanation. I STILL don't have my pistons flycut. Machinists are just a pain in the ***. Well, the good ones are. Bad with numbers and time, but good at their art. It seems to go hand in hand. I'm having to figure it out myself. I might just go the ghetto way and just get a cutter "valve" and do it with the pistons in the motor. I don't know. desperate words at this point.
#131
Love the cage, you and your passenger should feel very secure. What are you doing for doors? dash? I really wish my cage had door bars like that - I kept the stock doors so my door bars don't bow out like yours but run just flush with the inner sheet metal on the stock door (wanted to keep stock windows). Mine are a bit intimidating for getting in and out of which concerns me if there is a fire - ingress and egress should not be too bad with those.
Also, what is the sheet metal in the back of the car around the supports for your wing? Fuel Cell?
#133
It is a bit rough in the TIG department, but thank you SID.
My Dash is going to be quite unique. Almost a "False" dash, but you'd never know. I will post in the future and take many pics on this. In this thread.
The aluminum metal work is to separate the Fuel tank for the interior as the rules state. But maybe you haven't read the whole thread.. It IS a long one. I cut the whole back half off the car and rebuilt it using aluminum and fiberglass. These panels fulfill the most racing class rules and finish off and hide the wheel wells and Aluminum bars holding the rear of the car together.
But for my doors. I have fiberglass ones. I will be doing some pretty cool things with those also. Some aluminum Angle iron and a trick button to unlock the doors from the sill. (shaved handles ) Here's a pic of them in their current raw state.
#134
Just saw your roof intake, I have never seen a mid-engine 944 V8, this should be interesting.
My Pantera had shaved door handles with hidden buttons to pop the door electrically, very cool in a custom low-rider kind of way.
#135
Roof scoop for cool air on my neck.. AND.. it was an aluminum piece that fit my roof. I was desperately needing a roof. I'm very glad that chapter is over. But still, even I laugh at it often. I'm actually growing fond of it lately. It is quite tasteful though when compared to the ORCA car. Quite a large scoop even if it is for a trans cooler in the rear. I'm not too fond of that scoop.
no electric poppers here. Just a not so hidden button. And Pantera's are pretty cool in any way.
