Winter project under way. Updated 01/07
#78
Nothing. I kept it just in case. have something in mind?
#79
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Well so far in the last year I have been hit twice by non driving people so I was you can say just planing ahead for the dark enable ....hoping that it's all over now BUT it's always good to know where I may get a new one if needed you see?
#81
Thanks, but I hope the bad luck is over for my poor 951. But now I know where to go if so.
#82
This post has been added to the first page so you won't have to scroll through pages to get the complete story, all compiled on the first;
The cage is almost done. Door bars are last so That I can have room to fabricate other stuff and still be able to move. Please look at the second picture and look how tight I got the Halo and the A-pillar bars.. That was a ridiculous amount of work to get done properly and still be able to weld those bastards. Welding. Wow, that is very tough with a TIG and no where to support arms and stay steady. I now have to re-build the rear bumper beam/structure area to fit the fiberglass widebody rear. This is more exciting for me as I get to see a shape of the car. I have to get some more fiberglass parts soon though, and money is hurting right now with a one income household. I probably would have been close to finished by now if that hadn't happened.. Oh well. I will keep pressing. Additional pics below.
![](http://i508.photobucket.com/albums/s324/95ONE/cageupdate.jpg)
![](http://i508.photobucket.com/albums/s324/95ONE/tightfitRollbar.jpg)
#85
Man you aren't kidding....tight as hell, backside corners must've been a nightmare.
Either way, looks awesome. I can't wait to see the finish product....especially the power plant, let's just say I am counting on you this september
#87
I hope to be at the same weight I was before the cage build considering all the steel I'm throwing in the car. Praying the fiberglass pieces will make up for the over 100lbs of steel I'm adding back in. Hoping for less, but will be ok if I get back to the weight where I was before with a much stronger and safer chassis.
I'm starting to have doubts now that I'm adding in the heavier motor and safety equipment.
I still have the upper basket part to make. But that will be after I get most of everything done on the inside for easier ingress/egress
#88
it's a thing of beauty...
I love the A pillars and the sill bars...I have been looking at it for 5 minutes now
Are you cutting the rear floor and using a fuel cell??
And here I am slacking like A ****...money and time...of which I have hardly any
#89
Dude.. tell me about it. time I have. Money is now spreading thin. I shouldn't even be building this anymore. It's my crack though. I have to do it.
No. Sticking with the stock fuel tank. It's really light actually. I'm happy with it.
If you look at the cut off roof. You will see a little cut out square (both sides) that I did to weld the upper halo bar. -totally hidden. And then I had to wedge a pry bar in between the roof and the bar to make room to weld. After I did that, I mig welded the part of the roof touching to the upper halo area. I then mig welded the lower bars to the frame. I have some more cool guy brackets to make with the holes in it to tie the rest of the cage to the body.
#90
Amazing work as always. The fitment is the best I've seen in a 944/968 ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Why not a lower crossbrace that attaches to the top of the torque tube housing?
(below the crossbrace for the belts)
