Winter project under way. Updated 01/07
#211
The other stuff you mentioned has already been installed, like the Tilton pedal assembly, and Weltmeiser sway bar, or bought from others that have already copied.. lol. like my aluminum ebay trans mount.
#213
hah, thanks Duke. I'm waiting to post more pictures after I get the female rod end in. Then I can fab up the chromoly tubes in the flex plate and powder coat them. I should be done in a week or two.
In the meantime, I'm running the Oil tank feed tube through the frame rail. I had to take all the front right suspension off the car to do it. I went to put it all on, but found it wasn't necessary at all. It turns and rolls around fine with no droop. She's pretty light and stiff. Very happy with the results.
I am waiting on some A.N. weld fittings before I can finish the dry sump feed and return tubes. I'll be putting in/cutting out some exhaust paths on Monday. I will be making a remote waterpump mount this weekend. Some other finishing stuff too. She should be ready for paint - The tub - by next weekend. Not sure if my painter will be ready though.
Here's a pic of the car on only three wheels. No trickery, just 3 wheels rolling on the ground. EDIT>>> LOL>. I just noticed I lost a socket in the brake duct! I 'll have to get that out in the morning. How do they find their way into those places!?
#219
In the meantime, I'm trying to work out my remote water pump coolant system. Here's how most of my projects get started and figured out before any actual work is done. There are 3 other versions that I threw away.
#220
Some progress. The car has to be in the booth for a couple more days before my paint guy can continue. He's going to throw on all the body panels and give it the full race car paint scheme.
#221
Incredible.
#222
Fantastic improvement! You won't have any trouble seeing any dropped nuts and bolts!!
#223
Bruce, I know you've been told this numerous times but you're doing a fantastic job. Many people around the world are in admiration whether they post or not. I'm lookIng forward to the next phase!!!
