Loving my true Cold Air Intake
Looks good!
But yea it is way to cold for me out there and I had to work in it today...
And no I am no longer doing a rebuild, I am going to live with the coolant loss right now, but I will be replacing the chipset with the Lindsey Instant RWHP kit, right now I am collecting the parts to rebuild the engine in the Camaro to make it more boost friendly.
I dont want to do any major engine work on the 951 b/c right now that is my daily so maybe summer can bring me some more money to work on the engine. The only real project I have right now is to reseal the powersteering rack and the CV boot on the passenger side. I also am replacing the carpet and dash with black units and doing a rear seat delete with some walmart black speaker carpet (for now). Eventually I want to build a lockable storage area back there.
Also while the carpet is out I will be putting some sound deadener in the rear seat area, and replacing the rear speakers with some Sony units, and clean up the wiring. I also need to figure out why my drivers side turn signal keeps intermittently working .
I hope to do all this over my 10 day Xmas break, also during this time period, I will be laying a 30x72 concrete pad in the new garage!!
Drive-by provocation guy
Looks good!
Well I was trying to help you with the extra cash situaiton. lol
Maybe when you turn 18 you can be my local mechanic and I can just drop it at your house with a blank check and a wish list of things to do to my car.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Which Lindsey kit are you going with?
I am only going with the Instant kit, it comes with a chip set, FPR, and the LBE, as well as some wastegate shims, the car currently has old (1998) Authority Chipset, and it is running a little lean on the upper RPMs.
Also I am adding a new boost gauge and Ammeter on the Lindsey Gauge pillar pod.
Actually right now I have the end of the pipe wrapped in filter, not a tradition cone filter. I havn't noticed any drop in airflow but a tremendous drop in intake temps.
And as dyno tests have shown it is better, if need be, to flow less COLD air than more HOT air.
You should noticed a big difference with that kit and then can run 15psi.
Also, do you still have the cat in?
Before I was able to get my 3" cat back I just cut the cat out with zaw/cutter and clamped in a piece of 3" straight pipe.
If you can weld even better.
I have an electric zaw saw and compressor cut off tool if you don't have them.
So if not heavy rains or just non high revs if caught out in a down pour, there have been no issues.
the reason i ask is that there was an issue with 944's sucking in water and destroying engines back in the '80's. i haven't heard of it happening recently but do remember the warnings. i guess the water can't be compressed and literally breaks the engine.
am i the only one who remembers this?
Also, this is not a wide open pipe, I have it wrapped in air filter element so moisture can get in in heavy rain, but not a large amount of water.
Think kind of like a coffee filter effect. Only a few drops get in even when a large amount of water is suddenly put in.
I heard you sold your red 951 to Elliott?
Mine is running but always some little issue that pops up hare and there. I have new wheels (18x8/18x10) and new 90mm MAF and digital A/F piggy back and EBC.
And yes, it LOVES the cold air up here.
We have been in D.C. area for about a year now. Wife is working with DoD govt. contractor and I am working on my Masters. Real estate and mortgage was not the place to be for us anymore, obviously.
