Loving my true Cold Air Intake
Old 12-22-2008, 12:32 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Default Loving my true Cold Air Intake
Yea, kind of in the middle of a true CAI project and loving it with this cold air up here in D.C.
I can put pics up if anyone cares, but is just a pipe running from the MAF through the hole in the quarter panel area wrapped in air filter protector.
So this is getting ZERO under hood hot air.
Very noticeable difference in spool and throttle sucking in 20 degree air. Seems more noticeable in lower gears???
Old 12-22-2008, 12:57 PM
Dougs951
Dougs951's Avatar
Id like to see some pics of that, also are we still going to get together to work on your car?
Old 12-22-2008, 01:09 PM
toddk911
toddk911's Avatar
hey whats up!
Yea, still deciding if I want to change out the turbo or not. Plus gotta wait for warmer weather to work out side with no garage access right now.
You still doing the rebuild on your 951 motor?
Old 12-22-2008, 03:21 PM
Synth
Synth's Avatar
Let me know when and where, and maybe I'll join you.
My car still isn't right. It runs very rich and I can't pinpoint it yet, lol.
Old 12-22-2008, 03:36 PM
spoolin51
spoolin51's Avatar
share some pics....
Old 12-22-2008, 03:41 PM
toddk911
toddk911's Avatar
Sounds good.
What mods have you done? Do you have a piggy back for fuel control?
Old 12-22-2008, 03:45 PM
JimO
JimO's Avatar
Default sounds cool ..literally
Send some pics would love to see them.
Old 12-22-2008, 03:57 PM
Synth
Synth's Avatar
Originally Posted by toddk911
Sounds good.
I removed and replaced the engine and added a 4inch LR exhaust w high flow cat, LR Super 61 turbo, HV fuel pump, 3lb FPR, 72# injectors, LR stg. 2 intake, MAFterburner, MaxHP chip, new vacuum lines, new coolant lines, widefire HG, LR wastegate, MBC, and I think a few other things that I can't think of atm.
It is running extremely rich, and I'm compensating with the MAFterburner software, but I need to find the root cause. All the sensors seem to be ok, and I just noticed something that makes me think that the harness from the TPS to the DME may be causing a problem, so that's my current area of focus. It's been a bit frustrating though. Everytime I fix one thing, something else surfaces. It's ok though, I've replaced so much that once I get it running well, it should be fairly trouble free. *crosses fingers*
How's your car been? I need to get out to another thursday Cici's gtg.
Old 12-22-2008, 04:04 PM
toddk911
toddk911's Avatar
Join the club!!!! lol
I would look for leaks after the MAF. Air that has been metered is not getting to the intake so you are running rich.
Old 12-22-2008, 04:05 PM
toddk911
toddk911's Avatar
Well, no pics!!!!
I just went out to take them and pupping the hood and the cable let go/broke.
So now I can't open the hood.
Who wants to have a group car fix tonight???????????? lol
Old 12-22-2008, 04:13 PM
Synth
Synth's Avatar
Well, no pics!!!!
Lol, now that sucks ***. Gotta love old cars! I'd offer but the gf is off tonight, so my evening is kinda spoken for lol.
I did find a few small leaks, but it's more than that. I'm compensating -75 points on the MAFterburner to get it to run properly. It's running crazy rich. I'm pretty sure something is telling the DME that the car is running much higher in the fuel map than it is.
Old 12-22-2008, 04:20 PM
toddk911
toddk911's Avatar
major ***!!! lol
Are you sure the Mafterburner is actually adjusting the fuel?
Old 12-22-2008, 04:26 PM
Synth
Synth's Avatar
Yeah, I've double checked all the wiring, and the MAFterburner adjustment does make a difference. That actually reminds me, I need to call lindsey racing and verify that one of the voltage readings coming into the MAFterburner isn't out of spec. Another possible lead I forgot about.
Old 12-22-2008, 06:55 PM
toddk911
toddk911's Avatar
Ok, I got lucky!
Cable is ok, the lever part/connector is what broke so can fix that later as the hood can be opened and closed.
Attached are some pics. nothing fancy as I was just messing with the idea. I think I will run it with no pipe out of the MAF, but just the MAF itself at the hole in the fender with the filter wrapped on the MAF.
Mostly because the MAF is a 90mm (3.5") and now I have a 3" pipe to MAF 3.5" then back down to 3" into the turbo.
If the MAF directly then I can have a full 3.5" intake from the outside air into the intake track.
Even on super cold days under hood air is still well over 100 degrees. This way I am sucking in pretty close to ambient; i.e 30-40 degree air.
Old 12-22-2008, 06:58 PM
dillon410021
dillon410021's Avatar
I thought about doing that
Quick Reply: Loving my true Cold Air Intake
