K26/6 replaced by K26/8 the results..!
Our beloved "Faye" is an '87 UK spec turbo. We had to replace the turbo with a K26/8 as we couldnt get a K26/6. These are the results. The car is totally standard apart from a horrible cone air filter and a hard pipe set. This is one of only 4 rolling roads in Ireland....! Discuss
Faye on the Rollers reaching max
![](http://farm4.static.flickr.com/3046/3058801955_0850765580.jpg)
And the all important
![](http://farm4.static.flickr.com/3231/3059639692_d1e15a59c5_b.jpg)
Am I reading that correctly and they're saying that you've got approx 221 hp at the crank and 159 at the wheels? That's about a 40% loss? Seems a lot...
I think it should be about 10% loss although a 944 Lux was run earlier and showed 157 ay the crank and 102 at the wheels which to me is a brave loss as well ... Maha is the brand of the equipment used and is the only road that VW and Audi endorse (accoring to the lad who ran her...) I'm not too smart as far as graphs and readouts are concerned...!
Part of the IN Crowd
It has to be low due to the extra weight in the trunk. JK
Doesn't BHP mean different things in different countries? I know in the US we use SAE. Or am I completely off base?
Im more confused than ever......! The barrels of water in the "boot" were to give the car a bit of ballast whatever that was to achieve...! Im all tied up with HP, BHP, SAE, kW ... Help....!
