E-85 MEGA THREAD
#256
There is still a real dearth of people actually using E85 at higher than normal 951 boost levels on the track.
Headgaskets on our cars have been a weak point at sustained higher boost levels. I'll be following your progress.
#257
Drive-by provocation guy
I WANT E-85!! LOL
It is the answer to a 951 owner's prayers. Being able to run race gas, or better, all the time for cheaper than 93 octane in many areas.
I check the listings for new locations every few months and the closest to me is still 60+ miles away.
#258
Was that based on a 3bar (43.5psi) fuel pressure when you showed 420?
Also anyone interested eBay has a vast array of injectors from F.A.S.T. (19lb-160lb) 95lb'ers being 299.00 sent out flowed and tested.
On the link below you will see the Injector chart for 4cyl and max "flywheel" HP at the bottom.
http://cgi.ebay.com/ebaymotors/FAST-...#ht_2435wt_947
#259
Would it be to much to ask what size injector,turbo and boost these guys are using to achieve these results on E-85? Thanks.
7. 95ONE 415WHP / NO TORQUE (Dynojet)
8. Blown 944 410RWHP/445TQ (Dynojet)
#261
Are there any reliability issues between running 83lb. and 95lb. injectors? I hear the 95lb. injectors are more finicky? If so what is the reason for the finickiness?
What hp levels can I run with 83lb. vs. 95lb. injectors?
Once I have all of the parts in order(injectors,fuel pump and FPR) then who do I get to tune it for E-85?
I have the Lindsey 340rwhp kit. Do I need to get a reprogrammed chip or new software?
#262
I think you just invented a new word. 'Finickiness'?
Perhaps the perceived problem is just that it can become more difficult to run large injectors and get good cold start and idle, maybe even part throttle?
#264
#265
You can run much advanced timing. E-85 is cool. One of the guys on another forum could run his turbo RX-7 motor pushing 500 HP on E-85 and it would be cool to touch almost after dyno runs. It makes the car run cooler. Its just harder on the fuel system.
#268
Itīs nothing special ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Itīs not as wild as yours 333pg333![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
* Ported and decked NA head with flowmatched intake and headers
* NA Camshaft
* Adjustable camgear
* Bosch HFM5 Maf with special written software for gasoline and E85
* Modified IC.
* K&N filter
* Tial 38mm wg.
* Audi TT divertervalve.
* Spec Stage 3 clutch with aluminium pp.
* KKK KX5478 turbo (special made k27/8 with 360 bearings and flowprepped)
* 100 cells racekat.
* 3" exhaust
* Exhaust wrap on headers & crossover & downpipe
* Laust vacuum manifold
* 3 Bars BTR.
* Delphi 788cc injectors for gasoline
* Lucas 1260cc injectors for E85
* Bosch 044 Fuel pump
* O-ringed block
* Balance shaft delete
* Steam vent kit
* Gizzmo MS-IBC Boostcontroller
The engine is new build to this summer with new bearings and piston rings, balanced and lightened flywheel, balanced crank, pistons, rods, clutch, reinforced oil pickup tube.
Some pictures![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://www.garaget.org/?car=62649&image=1985259
http://www.garaget.org/?car=62649&image=1530804
http://www.garaget.org/?car=62649&image=1625784
* NA Camshaft
* Modified IC.
* K&N filter
* Tial 38mm wg.
* 3" exhaust
* 3 Bars BTR.
* O-ringed block
* Steam vent kit
Some pictures
#269
What sort of boost levels are you running on E85? What duty cycle are you seeing with the 1260's? How quickly are you getting through a tank of E85 at high boost?
Do you have a switch to flick between pump and E85 maps?
Have you had any issues with the headgasket even though I see you have O ringed head.
#270
Last year i runned 20psi but had som problems with coolant pressure.
I had problems with my headstuds that came loose so for this year i have a new block with helicoils for all headstuds and together with the steam vent kit and the o-ringed block i hope to stay out of trouble
I can switch between pump and E85 by using the codeplug in the motronic but then i need to switch injectors also, i never use the pump position, it was only for precaution if i didnīt pass the yearly inspection
Normal (hard) street driving i use up a tank in 500km or 310miles
At 17,5psi i have a duty cycle about 55-60%
I know the injectors are a little big but i bought bigger just in case i plan to build a 3.0 engine
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I hope that answered all your questions
Itīs fun to practise my english
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
