FS: Vitesse MAF, SMT-6, zeitronix etc.
SOLD-for the turbo, MAF kit (chip, etc.), SMT-6, forge diverter valve(with spring tuning kit), water adapter to get around coldside, Lindsey 3" downpipe with v-band on the exhaust side. Everything but the injectors to run this turbo.
-72# injectors-SOLD
-Zeitronix WB kit w/o display (egt sensor, boost sensor, WB sensor are included though)- $275
-DME- $175
-KLR- $150
-stock wiring harness - $100?
-Greddy profec B spec II- SOLD
-Stock IC-$75
Turbo is a 750 crank hp turbo, with a #10 hotside. This turbo produced 15psi at 3300rpm on my relatively stock 951 motor and SFR stage 1 headers.
All of these parts are in good working order, as a matter of fact I drove the car today with all these parts.
-72# injectors-SOLD
-DME- $175
-KLR- $150
-Stock IC-$75
Well it runs but the stock wiring has bad insulation/frayed connections in some spots. Every once and a while I get hiccup or some other issue related to a bad point in the harness. Instead of pulling the harness checking all connections and replacing all the bad points to only put the stock harness back in seems counter productive to me. Also I like to tinker with the car alot so I will get to play with all the new neat standalone features
