Some ?'s about 3.0 turbo conversion
#32
Man checkin that out would be pretty sweet. Is the garage open tomorrow? I just hate tellin you Ill be there, then something comes up. Saturdays are like that for me alot. I can handle the not being hung over that morning....haha, its a meeting or having to go out of town, or family that usually inhibits me on Sat mornings.
#34
Here's a partial list. If you start putting bargain prices next to each, you will quicly see why it costs more than you might think....
Block
Black machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Bottom end gasket kit
Oil stone for pump surface
Various sealants (Assembly lube, loctites, etc.)
Head (951 exhaust, 2.7 intake)
Head machining
Intake port matching
Thermal coatings (2.7 head)
Head gasket set
Balance Shaft bearings
Rollers, t-belt, b/s belt
Waterpump
Thermostat (2) and clip/o-rings
Re-using old hoses?
Oil pump (used s/b ok)
Head studs/nuts
Exhaust seals
Cam (optional)
Many miscellaneous seals (aluminum rings, o-rings, etc.)
Replacement fasteners (they break)
Turbocharger (for 3L)
Engine Management (Chips, VR board, s/o, etc.)
MAF or MAP
Flywheel and PP machining
Clutch disk
Flywheel/PP bolts
Throwout bearing and guide tube
Tools (ring compressor, bolt stretch mic, etc)
Accessory belts, hoses, plugs, wires, etc. (maintenance items)
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Block
Black machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
#36
Monkeys Removed by Request
Block
Black machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Block
Black machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
*edit* who am I kidding? I don't do my own wrenching. Its someone else's labor and my love
#37
Block
Black machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Block
Black machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Jeremy: Just getting home right now. Too many errands today. Still gonna have that thing on the rack next week? DJ brought a powerhaus 3.0 16v to check out on Tues. I think powerhaus is trying to sell the parts. haha. Thing is ive sourced the parts for a bit over 4k, powerhaus is wanting like 9k. Waiting for partsheaven to get back to me Mon. With the final price.
#41
4-5k for block, pistons, rods, head, crank is tight? Ive sourced the head for 375, crank for 1200, pistons/rods for about 1600, waiting on an exact price on a block somewhere a bit north of 1500 at most. That adds up to 4675. So around 4-5k. Theyre insisting on using a 89' 2.7 block, and head. I was told you have to change the head studs to put the 2.7 head on a 968 or s2 block. Also that it wasnt advisable to change the studs. I thought they were all the same block??
#44
