My Upgrade Plan, thoughts?
Old 10-31-2008, 07:24 PM
  #46
amirpc
amirpc's Avatar
Originally Posted by spoolin51
Amir, IMHO when it comes to wastegates it really dosent get better than Tial.
Yeah, I just got off the phone with Tim over at speedforceracing. Real nice guy, I got the whole thing including gaskets and flanges, etc for $410 or so shipped. I could have done better, but Vic of Pauer Tuning was kind of a dick.
Ended up getting a 38mm Tial w/.8 bar spring.
Old 10-31-2008, 09:52 PM
  #47
DDP
Rocket Scientist
DDP's Avatar
LOL
Old 10-31-2008, 10:06 PM
  #48
spoolin51
spoolin51's Avatar
well done!
thats a nice setup!
Now, are you doing any exhaust upgrades?
Old 11-01-2008, 04:18 PM
  #49
amirpc
amirpc's Avatar
well done!
thats a nice setup!
Yeah I think I'm going to save that as an after christmas christmas present to myself.
Old 11-01-2008, 08:43 PM
  #50
amirpc
amirpc's Avatar
Wow, on another note. Getting the windshield washer tank out is like, an epic process. I failed
Old 11-01-2008, 09:50 PM
  #51
spoolin51
spoolin51's Avatar
LOL, dude i had to cut mine out
Old 11-01-2008, 10:59 PM
  #52
CarbonRevo
CarbonRevo's Avatar
I think I got confused on something, or misunderstood a part. I have 48# injectors coming with my Vitesse MAF setup. Should I get a 3bar FPR or not? From how I interpreted an earlier post, it sounded like you don't need it...but that didn't make much sense. Can anyone clairfy?
Old 11-01-2008, 11:50 PM
  #53
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
Yes get the 3.0bar FPR. You can order them from john he can ship it with your kit.
On a side note does anyone know of the max output(psi) for a adjustable FPR for our cars is? Whats safe fuel pressure. I have the standard 3.0bar FPR but, after reading about the e85 stuff im a little concerned my fuel setup won't be enough for e85(044 pump, 83lb injectors). Would buying a adjustable FPR and increasing the fuel pressure a good bit help me out?
Also would it hurt anything to do it like that. I understand its just better to buy the right size injectors the first go around but, stupid me I didn't think that far ahead(I was coming from 55lb and a fat fuel curve I thought the upgraded pump and injectors would be more than enough for 400whp).
Any tips/advice would be appreciated.
Old 11-02-2008, 04:22 AM
  #54
spoolin51
spoolin51's Avatar
^ John im sure the 044 pump will be enfough for E85, no?
Just injectors need upgrading... What are you going with....1k?
Old 11-02-2008, 04:37 AM
  #55
porshhhh951
no thats the problem. Already have 83lb in the damn car and this is the second set. I really don't want to spend another 400 bucks on injectors. If I could get away with spending 200 bucks on a adjustable fpr that would work alot better.
However I don't want to do that if it isn't safe and i'll be honest im not looking for crazy power. I'll only be running higher boost pressures on e85 and even then it won't be the norm.
I'm hoping the v-flex software will allow me to run 18psi on pump fuel safely(hell I did that for years on my old setup but, I know this is different now). If I can run 18psi safely i'll be happy with whatever 3ish more psi can give me with e85.
I'm just trying to find out whats safe or not. Everyone says something different and not that john isn't helpful but, he has to protect himself. Its why he says no more than 15psi.
However I know people run more than that on pump gas and race gas. I'm just trying to figure out what the line is, turn it back one notch and be happy. If its only 15-16psi then thats fine. If I can run 17-18 and be safe I will.
E85 is the same thing. I just want to find the safety line and make sure I never cross it.
Old 11-02-2008, 04:42 AM
  #56
spoolin51
spoolin51's Avatar
^Yeah I hear ya. On E85 at what boost level do you start reaching that "line"?
Old 11-02-2008, 05:23 AM
  #57
porshhhh951
exactly. Just for my setup. For pump fuel and e85 whats a safe boost pressure level?
Everyone seems to have a different answer. I know its probably more than 15psi on pump but, how much more is the question. On e85 with my injectors, pump, and 3bar fuel pressure whats the most I can run then?
I really hate to play trial and error with this brand new motor and turbo. I'd rather someone just be able to say "oh yeah I have a similar setup and I ran 17psi all day long no problem etc".
sigh searching results aren't giving me much direction either.
Old 11-02-2008, 06:33 AM
  #58
333pg333
333pg333's Avatar
Provided the motor is built to take higher psi and you have all the supporting components for E85, you can run 17psi easily!
Something to bear in mind is that no matter how 'ready' our motors are to run higher boost, it still ages the internals faster, all things being equal. Having said that I will be looking at 24psi as a sort of 1st stage ceiling.
Old 11-02-2008, 07:17 AM
  #59
porshhhh951
aren't you a 3.0ltr though?
I'm just a lowly 2.5 with stock internals(fresh rebuild).
Old 11-02-2008, 07:37 AM
  #60
333pg333
333pg333's Avatar
Not at the moment John, otherwise I would have left that 996tt in my dust. I've got a refreshed totally stock 2.5L motor with the VR5 kit. I'm playing with a bit of E85 at the moment and using the SMT6 to get the afrs right. With the V-flex kit you'll be fine for 18psi easy IMHO.
Quick Reply: My Upgrade Plan, thoughts?
