How much power can one expect to gain from 2.8 stroker?
10-13-2008 | 11:57 PM
Im considering having this done since my engine is out anyway. What kind of power can I expect to gain?
10-14-2008 | 12:22 AM
Depends....What are your goals?
10-14-2008 | 12:25 AM
Yes! and what mods does it currently have? ..what else would you be changing?
It's got a Vitesse S3 turbo?
10-14-2008 | 12:40 AM
Lindsey MAF, mafterburner, dual port, steam relief kit, MBC, uego wbo2, 3 bar fpr, 3" exhaust, 55 lb injectors, 951max chips, and probably a few other things I cant remember off the top of my head. I was thinking I would do 72 lb injectors, and racing fuel pump.
10-14-2008 | 12:41 AM
Oh yeah, yes Vitesse stage 3, and cometic.
10-14-2008 | 12:50 AM
The ImpalerRennlist Member
It's allot of cost, stick with your 2.5 and use the money elsewhere...
10-14-2008 | 12:51 AM
Yeah its not cheap. But if I gain significant power could be worth it.
10-14-2008 | 12:54 AM
Quote:
Originally Posted by
tone3721
Use that money elsewhere, you can gain more power for less $$$
of course this is only my opinion.
Have you already purchased a good wideband and etc? The cost of a stroker would be a good chunk of change to spend on some nice electronics.
What are you doing for your clutch?
10-14-2008 | 12:56 AM
Lorax
Yeah, read posts 4-5. Clutch is new, with new cylinders, has 930 disc.
10-14-2008 | 12:58 AM
tone3721
oh ok... just saw that.
well why not sleeve and bore instead?
Then you get more displacement and nice tough steel cylinders.
10-14-2008 | 01:01 AM
Stroking seems like it would be much more reliable, even with sleeves.
10-14-2008 | 01:05 AM
Rocket ScientistRennlist Member
I think your time would be better spent in search with people that have actually done this before. You can find dyno results with bore vs. stroke, different turbos, etc.
10-14-2008 | 01:10 AM
Spend money where it counts. - tuning.- standalone.
10-14-2008 | 01:16 AM
tone3721
Much more reliable? Who says?
10-14-2008 | 01:37 AM
Well not sure what more to do. What more bolt-ons could I add?
Correct me if Im wrong, but the 2.5 walls are somewhat thin anyway. Wouldnt boring them lead to head lift? Causing HG failure?
