Brake duct mounts
Brake duct mounts
Does anyone have a template, or a current source for purchasing these, besides LR? I can fab them up if need be, so a template or scan or hell, even a picture and some measurements would work. The backing plate mount is what I'm looking for. Thanks!
FYI- you don't really have to make them slide over the spindle and bolt in three places. I made some simple ducts that attach using a single bolt (one of the backing plate bolts). In 2+ years of racing they have never moved and work fine.
Cory, do you have any pics of this setup??
Dan, thanks for the offer, but I can get all of the stuff I need for free from the shop! I already have all the hosing I will need. I think i will end up replacing my ft bearings and while it's apart, I'll use Metrolog to create a digital copy and water-jet it out once I convert it from a .CATpart to a .dxf file.
why not copy them but use just 2 bolts?
I think i wil just crudly hole saw the factory splash back and just weld tube in .
i keep thinking about those varius 9"x 5" carbon fibre funnels from nascars for the front that i see on evilbay
