Boost meter wont move.
Wax On, Wax Off
either not boosting or a hose is disconnected.
fix the hose, trace it to find a leak... but most likely, I'd say you should check the vac lines going to the KLR. it is under the carpet in the passenger side footwell. that's what I tapped into when installing my boost gauge/ boost controller. with that, if it's broken or disconnected, it should be easy to repair.
