Help! losing fuel pressure after car is turned off
I noticed lately my fuel pressure has been dropping after i shut off the engine.
The gauge i have usually reads around 40psi at idle and goes up a few psi under revs. Once the car is shut off it will drop to 0 in about ten minutes. Is this normal or do i have a leak somewhere?
mine does that- new injectors, regulator, gauge and fuel lines. Bet its the check valve bleeding off. No biggie just takes a crank to get the fuel back up to the rail.
Wouldn't it pressurize before cranking, or does the DME control the signal to the pump?
Many cars you can hear the pump turn on with the key.
depends- if you turn the key on and then wait to crank - but usually i just put the key in and start cranking. Technically if you put the key in, turn it to the on postion, then crank it would build pressure before you crank yes.
Thought so. I wait always wait to crank it from the on position. Not sure why, just one of my habits.
Mine leaks down too, but takes 2-3 hours to fully drop to zero. I'd say it's a very leaky injector, or the check valve as stated above. That's a pretty big/fast leakdown if you ask me.
