Upgraded Axles from The Driveshaft Shop
Old 12-27-2008 | 06:25 PM
  #166
ehall's Avatar
ehall
those 924 pics are awesome.
Old 12-27-2008 | 07:24 PM
  #167
A.Wayne's Avatar
A.Wayne
Formula One Spin Doctor
Originally Posted by anders44
im going for over 500WHP, and over 7-800nm though...
same for mr 333pg333, we are both nutters.
my personal economy is still very good, but with the currency beeing ****ed, a GT2 tranny is now 45-50% more expensive than it was 3 months ago! :|
as for axels, I never managed to brake a single 1, in 2 seasons, on 285 and 295 R spec rubber, launching hard, going sideways, regular track duty, drags etc... not a single tranny either, but I'm getting over 100% more volume now that should help.
Try to cryo the stock axles ( best bang for buck to stock axles ) After this you will have to do the mods necessary to fit 930 axles. The modded after market axles are stronger than stock , but not enough not to fail and not as strong as the 930 axles.. The 924gtp uses 935 axles modiefied to fit and yes stock is strong enough for 400 ft/tq once you are not launching the car ....
Old 12-27-2008 | 08:59 PM
  #168
gt37vgt's Avatar
gt37vgt
that pic kind of explains why I'm considering steel trailing arms
Old 12-27-2008 | 09:23 PM
  #169
daigo's Avatar
daigo
yup, me too.
Old 12-27-2008 | 09:48 PM
  #170
gt37vgt's Avatar
gt37vgt
so will the 951 brakes go on to 83 951 N/A arms ? how many different brake mounting types are on the arms ?
Old 12-27-2008 | 11:14 PM
  #171
A.Wayne's Avatar
A.Wayne
Yes change the ball joint for the 951 hubs ...............................
Old 12-27-2008 | 11:31 PM
  #172
gt37vgt's Avatar
gt37vgt
what ball joint? i am talking rear arms...
er do you mean put the 951 hubs into the steel arms ?
what a realy want to do is a strait swap and put the alloy arms into my 83 na ? can this be done ? and each car retain its own brakes ?
  #173
gt37vgt's Avatar
gt37vgt
Old 12-27-2008 | 11:33 PM
  #174
gt37vgt's Avatar
gt37vgt
so that means there is 17 and 19mm bolt on front ball joints i guess .
Old 12-28-2008 | 01:22 AM
  #175
A.Wayne's Avatar
A.Wayne
Yes to both questions ... i was talking front arms ,,, i would use the alloy rear arm
and do the fab work to convert to universal joints , ala 935 ....
Look into using 930 axles , if not cryo the stock ones and service frequently for track use ....
Old 12-28-2008 | 05:22 PM
  #176
333pg333's Avatar
333pg333
What exactly happens with Cryo treatment? Is it proven to work and by whom?
These aftermarket axles that you refer to as "stronger than stock but not the 930",
are these the type that was mentioned earlier in this thread at $1000? Also, if going to a much stronger axle and perhaps UV joint, what gearbox?
Old 12-28-2008 | 06:59 PM
  #177
gt37vgt's Avatar
gt37vgt
they freeze the parts for a few days witch apparently equalizes the the stresses with in the metals and apparently aids the uniform structure of the of the ion matrix.
Old 12-28-2008 | 07:13 PM
  #178
daigo's Avatar
daigo
Has anybody researched the Hewland box that some of the factory race cars came with? I've got photos somewhere I can post. Fits very nicely.
Old 12-28-2008 | 07:17 PM
  #179
gt37vgt's Avatar
gt37vgt
yeh thats what i would have used if i chose to abandon all budgets. I still feel that my 968 box is indulgent it is worth more than the rest of the car
Old 12-28-2008 | 07:18 PM
  #180
gt37vgt's Avatar
gt37vgt
yeh thats what i would have used if i chose to abandon all budgets. I still feel that my 968 box is indulgent it is worth more than the rest of the car and that 3 of the
Quick Reply: Upgraded Axles from The Driveshaft Shop
