Need advice, buying rings, bearings ect for engine rebuild
I have the engine ready for the complete refresh, first this is an engine that was running without problems, just want to do a complete engine rebuild to make sure. I am going to change headgasket, main bearings, rod bearings, all seals, complete head work, piston rings,heads studs, water pump and timing belt job. I will take the block to machine shop to see is at spec and do a honning for the new rings. My question is where is the best place to get this parts?? Also what is best to buy factory porsche and what can i buy aftermarket?? I was searching the piston rings post, which are the best one?? My car would be a daily driver (no track use) with minor mods: Lindsey MAF, K26/8, 951max chips, 3" exhaust, boost controller (17 psi max), 38 dual wastegate, 3bar regulator, new inyector 55lbs and new HP fuel pump. Also new clutch. Should I buy a complete rebuidt kit or buy separate this parts?? Thanks in advance
do not HONE the block. If the bores are clean, you can get a shop to do a finishing pass, with felts, oil, and paste; this will expose enough material; some people install new rings in old bores, I'm just not a fan of it.
Paragon first choice, LR has a complete kit that even has the proper loctite, then EBS. Aftermarket rings are available for $100, Porsche ones are $400.
Good thread as i'm sure this will be in my future. Eatiles thats a nice list of mods, do you plan to do the engine rebuild yourself?
Ski, could you clarify. When doing a finish pass on the cylinder walls are you saying it is then ok to use new rings or would you do a finish pass on the walls to freshen the block but still use the old rings. I think your saying finish pass cleans enough material off to go with new rings, just want to be sure. Thanks.
I have a friend who is a certified mechanic and he build several of this car already, He is going to supervise me during the process. I know that when you take out the rings you cant reuse them. I think He means for the new rings.
Nice, always good to have a friend watching out for you.
Good luck with the build, don't forget to photo document for the rest of us.
Part of the IN Crowd
So is the aftermarket stuff acceptable better or worse then OEM?
I am currently rebuilding my engine and would like to know the difference.
I see that in Paragon the piston rings for the turbo are different from the n/a 944, in other sites they sold the same rings for every car (turbo and n/a), also note that the price in the paragon turbo rings is higher that the normal, what piston rings brand paragon sells for the turbo??
