Pulled the head today
#32
We have a couple of tricks we use around here to keep the MLS gaskets from weeping.We use MLS gaskets on just about every motor we build here.From BMW's to Toyota's, the MLS have worked very well. And for trick of the trade..........We use a small amount of silicone around the water jackets before we install the head gasket.If you do this,the MLS wont leak externally or internally unless ofcourse your head lifts.
#35
She's back together, slight exhaust leak and a 1200 rpm idle to sort out.
I want to flush out the coolant system, is the Prestone stuff ok to use ?
![](http://forums.rennlist.com/upload/mvc015s_copy3.jpg)
![](http://forums.rennlist.com/upload/mvc014s_copy7.jpg)
#42
Good news David. By the way, is your header panel a modified stock metal one or something else. Looks like a neatly modified stock one judging by the thickness. Have you done a c/r test and if so what numbers are you getting?
#45
Basic Sponsor
I sold a custom welded wastegate to x-over pipe, good job and it seem to be a solution for this comom problem on 951's
http://cgi.ebay.com/ebaymotors/ws/eB...215119553&rd=1
