OK...what's this...? ("clunk" in the rear - rv)
I finally get the electrical mess figured out with the harness (turned out to be a combination of a few things) and cruised around the block for first time in almost a year!! OMG....can't wait to get it tuned. Anyway, I'm now feeling a "clunk" in the rear when i take off or shift through the gears (ugh!!) It wasn't there before the tear down/rebuild and have been informed that it sounds/feels like the CV's are shot!! At least the right side. Could they do this if they're in a different position than they were before ?? If someone has any experience with a bad CV joint can you describe how it sounds or feels when they're on their way out. I would appreciate it. And, if that's what it is, can you recommend a good source for rebuilding them and/or the best way to go about it and where to get parts? Thanks in advance for the assistance...
...this isn't a "click" it's a "clunk" you can definitely feel/hear something. It happens almost every time i let the clutch out or shift. By grabbing the CV axle with my hand and pushing it toward the wheel i can make it hit something... in the boot? Is this normal? Could the axles be thrust outward like this when the diff starts turning? Who would be the best source for parts? THANKS
Start with checking anything you may have had apart back there during the teardown. Torque tube, trans mounts, shifter linkage, etc. A noise like this should be able to be duplicated with the car in stands.... carefully. I had a customer in here recently with the same type noise, and it was the left CV axle hitting the hub with very little effort.
My exhaust backbox (muffler?) clunks sometimes, espeicially on downshifts. There is no detriment to the feel of the car - just an audiable clunk as the box swings against the heat shield. I have an aftermarket backbox that is alot larger than the stock item so there is less clearance.
Doug - did exactly that...went through every bolt & nut from the bell housing back. Even checked the shock mounts and all were tight. How much effort does/should it take to move the axle?
Dan - brand new clutch, disk & FW
Thanks for all the input, sounds like it's pointing to the CV's. Any advice on where to get parts to fix?
