I'm done, make me an offer...
#241
Monkeys Removed by Request
couldn't agree more. I like having one shop do absolutely everything. The final product is always better. Its part of the reason my car ran so good when it left lindsey. They did everything....
#242
First, I am the "random shop" that worked on Richards car. We did some suspension work,replaced the seats and traced down a problem with his alt guage and oil pressure light flickering intermittently. The car was here for so long because Richard said he was in no hurry and we were extremely busy and if I remember correctly a good portion of that time the weather was too bad to drive it anyway. What we did was pull his intrument cluster to fix his guage problem. We did not go anywhere near his wideband in the center console. If his wideband quite working it was because of whoever installed it! Not because we pulled his instument cluster out. To try and blame an engine failure on that is very unprofessional if you ask me. If I had built an engine that failed after 4500 miles I would have stepped up to the plate and taken care of it. That is what should have happened in Richard's case. Instead, Dave is continually trying to blame other people for a tuning mistake or improper torque of a head. That is most unfortunate. The pictures can tell you alot if you know what you are looking at. The wideband not working is a convienent excuse to not take responsibility for the problem in my opinion.
I do not like to get involved in situations like this. I do not like to comment on anyones work or business practices but I feel like I need to defend myself because I was brought into this mess. I did not create it. I have been working on Porsches since I was old enough to hold a wrench. We have been in busniess for close to forty years working on Porsches only. I will put our reputation against anyone. I am not a "tuner shop" We are an independant Porsche repair facility that does things right. If we make a mistake, we step up and take care of it. That is how you stay in business for forty years workin on one manufacture of cars.
I think it is sad that I had to even post this....
#244
Yep, that's his name. It's been a while.
#247
Basic Sponsor
Chigurn strikes again
#248
Basic Sponsor
and another 89 951 from another rennlister cyrus951, it runs great, I had fun driving the car for a couple of days but .........
#250
Basic Sponsor
Blew a head gasket...I am done. Make me a serious offer and get this thing and all the associated stuff out of my garage. Lots of good parts, I am just tired of it.
89 Black on black. Lots of stone chips on every front surface and dash as a few cracks. 190,000 miles on body.
4500 miles on...
2.8 Stroker.
3.0 liter knife edge cross drilled crank
Pauter Rods
J&E Thermal & Friction Coated pistons for 8.5:1 compression
LR oil pan baffle
Stage 2 O-ringed head with race springs and steam vent kit
Extrude honed TurboS intake
Hard pipes
Super61 P-trim Wet Turbo
LR stage 2 intercooler
LR MAF
MafterBurner
Zeitronix wideband with boost and EGT sensors
LR headers
Coated Crossover
LR Dual Port Wastegate
Maxx951 chips
3 in downpipe
4 in exhaust with MagnFlow muffler (93 db)
Aluminum Flywheel with fresh friction surface
Spec composite solid puck clutch (stage 4)
25K miles on
Koni Yellows rebuilt/replaced
Stock Turbo S calipers powder coated red
LSD tranny rebuild
New
80-410 progressive front springs
30mm Welt TBars
Welt Adjust front and rear swaybars
968 Sport Seats
Starter
Alternator
also has
8 and 10's 2002 Carrera 5 spoke lightweight wheels w/225F and 285R
Also in garage
Batwing and body pans
beat up AIR splitter
Dark Brown Sport Seats
Stock 4way seats
968 mirror kit
928 style shark antenna kit
Original 2.5 Rods
used half shafts
Box of misc stuff including shop manual copies.
Gimme $10K and it's all yours.
4500 miles on...
2.8 Stroker.
Pauter Rods
LR oil pan baffle
Hard pipes
LR MAF
MafterBurner
LR headers
Coated Crossover
Maxx951 chips
3 in downpipe
25K miles on
LSD tranny rebuild
New
30mm Welt TBars
968 Sport Seats
Starter
Alternator
also has
Also in garage
Stock 4way seats
968 mirror kit
Original 2.5 Rods
used half shafts
Also in garage
Stock 4way seats
968 mirror kit
Original 2.5 Rods
used half shafts
#251
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Lart,
you truly are a madman.
and like Patrick said, the op got off easy.
and I can't believe you didn't make note of his Lapsis blue shark avatar.
are you slipping - or just having an off day?
#253
