how much have you paid for a 4 wheel alignment?
Old 01-10-2008, 10:17 AM
turboted
turboted's Avatar
Wow...I think I just got screwed. I just had all 4 wheels aligned after my rebuild and it cost me $450. Of course, I had pulled the entire front end of the car off and just eyeballed everything when I put it back together, so the settings were WAY off. But still...... Maybe I need to find a new shop.
Old 01-10-2008, 10:22 AM
reno808
reno808's Avatar
free i got da hook up.
Old 01-10-2008, 11:03 AM
Stuttgart996
Stuttgart996's Avatar
i think i am just gonna go to the dealer, i just went and they said 250 for a 4 wheel alignment on any Porsche, let me know if you guys think this is a good call.
chris
Old 01-10-2008, 11:09 AM
reno808
reno808's Avatar
chris
with your specs or factory specs? corner balanced as well?
Old 01-10-2008, 11:17 AM
951Tom
951Tom's Avatar
Vwvortex, 2 local dealers quoted me $250 also. I ended up paying $150 at a shop that had a Hunter 4 wheel laser alignment. There is a shop locator on their website.
Old 01-10-2008, 11:28 AM
2bridges
2bridges's Avatar
paid $350 for a track alignment / ride height/corner balancing.
Detailed specs provided before and after - corener weights, etc.
Corner balanced with ballast dummy in drivers seat to drivers (Me) weight.
NOTE: not a firestone or tire shop... Local race shop - experienced 944Turbo racers that build/maintain/race 944T
Old 01-10-2008, 11:40 AM
reno808
reno808's Avatar
Is that your way of justifying the cost lol. Many high end race shops do charge that.
Old 01-10-2008, 11:45 AM
xsboost90
xsboost90's Avatar
ted- almost every car i have aligned is because ive had the entire front/rear suspension out or a new rack - find a new shop!
Old 01-10-2008, 11:48 AM
2bridges
2bridges's Avatar
hahahaha - no justification needed for me
just don't care to hear some genius telling me how I can go to firestone for 89.99 and get the same thing.
btw: you got anything heading my way.....
Old 01-10-2008, 11:56 AM
reno808
reno808's Avatar
Yeah i know what you mean. If i had to pay 3 something knowing how my car handled at the track i would of payed without even thining about it.
Yeah you do. But you already know that
Old 01-10-2008, 12:08 PM
cas951
cas951's Avatar
When I first bought my 951 S in 2002 I took it to Wheel Works. They required 4 wheel alignment and they charged I think it was $140.00. When I gave the go ahead they offered me a lifetime alignment for the car for $350.00. I took the bait and I've been taking it in every year since.
FYI... Don't ever go to Sears. A friend of mine had his 87 951 aligned at sears for $75.00. I decided to take the wife's Boxster S there. Boy did they really mess up. On their initial alignment reading all 4 wheels were way off and said they could not adjust. Took it to other specialist to get their opinion. They look at the printout Sears gave me and said the same thing. According to the readings the car is basically rolling sideways. I took it to wheels Works and had them do the alignment and there was no problems at all. I compared the initial readings with ones from Sears and Sears were way off.
Old 01-10-2008, 12:14 PM
reno808
reno808's Avatar
yeah there machines where not calibrated. Those things get used ALLOT
Old 01-10-2008, 02:29 PM
Fishey
Fishey's Avatar
$0
Did it myself at the shop on 3 cars...
Also, the 944 is a very easy car to align the only downside to it is race cars are usually beat so they take forever and I have seen alot with stripped out rear plates that make adjusting camber impossible. Also, for the love of god if you put on new tie rods use some anti seize.. Also, just to note it takes me about 1/2 the time to set camber without plates as it does to set camber with adjustable camber plates. The factory setup is fast can can be done with the car on the rack. Aftermarket plates will not allow you to adjust them on the ground as they have to much pressure and always want to go to one side.
Old 01-10-2008, 02:53 PM
gjoey66
gjoey66's Avatar
Make sure they actually have the tools..."special tools" for aligning the rear...if not they'll just say screw it...make some tweaks...but they can't adjust the rear without these tools...even some dealerships didn't have them...i finally found a race shop that used to race 944 turbo's and they are doing it as we speak
Old 01-10-2008, 02:56 PM
gjoey66
gjoey66's Avatar
oh and for an alignment and corner balance...you chase your tail a bit...so 350 sounds very reasonable...it's about 3-4 hours worth of work...mostly because you add a few more variables that are changing...especially if you have a particular ride height in mind
Quick Reply: how much have you paid for a 4 wheel alignment?
