do i have to remove my crosspipe to remove clutch? (pic)
Yes that is a two piece cross over pipe. I guess it doesn't need to come off.
clarks-garage.com has a write up to help you through your journey
thanks a TON everyone!
i've been following clark's garage instructions.
anyone know how many bolts there are on the clutch bellhousing, and can they all be accessed through the bottom?
I like to get the passenger upper bolt from the top, but everything else is from the bottom. The driver's upper bolt takes a couple of LONG extensions and a universal joint to get.
You forgot the cursing. I like to get that top one by the ref sensors from the top also, and you dont need to remove the intake to get at it well at least I dont
