anyone know how to reach RBerry@maxhpkit.com?
tried emailing him and keeps getting bounced back. I need some chips for my 86 944t - currently have a Lindsey 3” w/ no cat, tial 38mm, and im getting a set of 55lb injectors. I’ll be getting a 3bar regulator asap. How much for some chips tuned to this combo? Ive been hitting boost cut at 11psi on the track and it really upsets the car- I believe because I have the 1bar wg spring and it is pulling too much air through the barn door when its hot out….
nevermind i found the alternate email address in a search. ANyone else using this setup w/ a stock 26/6? Im setting things up so eventually i can get a vitesse turbo and MAF setup- eventually.
My setup is pretty similar. Using a 26/8 though w/a 46mm Tial. I have been happy with the chips. I believe you can purchase them right off his site (http://www.maxhpkit.com/). Just search under products.
ok- got everything i need except for chips and a regulator- i'll get a regulator and order some Rberry chips in the next week or so.... !!!
edit- regulators on the way- just need chips!!!
