Why do these cars make your clothes smell like fuel?
Old 09-03-2007, 07:11 PM
  #46
bearone
bearone's Avatar
no smell of gas with windows up/down and carport doesn't smell like gas. testpipe.
87951
Old 09-03-2007, 08:40 PM
  #47
reno808
reno808's Avatar
Originally Posted by azbanks
You've got to pull the passanger side hatch carpet and it is between/under the fuel tube to the tank and the fender. You do not need to pull off the metal cover over the gas tube.
If you look at your gas cap you will see a little black rubber drain hole right near the edge of the fender. That is the beginning of it. The rubber piece connects to the clear plastic hose that goes down behind the fender. That hose T's with the line coming down from the sunroof. The hose does not look robust enough to be a gas tube but it doesn't move much of it.
I should have taken pictures when I did mine.
I did that this weekend. It took me like 15 minutes. the "T" was pretty easy to locate and take apart and clean.
Old 09-03-2007, 09:09 PM
  #48
TRWright
TRWright's Avatar
Mine was very easy to get to-- it is right behind the carpet. Maybe they changed it on later cars. Anyways, mine was clear-- no blockage.
Old 09-03-2007, 10:29 PM
  #49
reno808
reno808's Avatar
Mine was BLOCKED i had to pick it out with a screw driver because compressed air wouldnt work
Old 09-03-2007, 11:05 PM
  #50
SD Porsche Fan
Cast Iron Man
SD Porsche Fan's Avatar
I had a leaky fuel rail. Once I replaced it no more gas smell.
Old 09-03-2007, 11:54 PM
  #51
xsboost90
xsboost90's Avatar
mine wasnt blocked, it was disconnected...
Old 09-04-2007, 01:10 AM
  #52
Blueman33
Blueman33's Avatar
the replies seem to be for a raw gas smell and an exhaust smell.
many cars smell like exhaust.
drivers THINK they 'reseal' the hatch by replacing the gasket...........but they missed the point.
the seal is fine.
it's the hatch that is bad.
IF YOUR HATCH HAS BEEN PUSHED OUT BY 20 YEARS OF FORCE FROM THE REAR LIFTS, IT DOESN'T MATTER IF THE SEALS ARE FINE BECAUSE THE HATCH HAS MOVED BACK ENOUGH TO CAUSE A LEAK.
check out
1. the top of the glass by the frame. if there is a space between the glass and the frame at the top, you are probably screwed.
2. if you get into the back hatch and feel the rubber seal when hatch is closed and you feel places most likely in the very rear that the seal is not compressed, you are probably screwed.
it's not the seal,..............it's the hatch.
if you find you need one, sunset is less than $1600 delivered and i got nine for $200 used....but remember.....MANY MANY HATCHES HAVE SEPERATED...so don't buy a used one with the same problem.
my $.02
Old 09-04-2007, 08:49 AM
  #53
xsboost90
xsboost90's Avatar
ive had some hatches leak and i just had to pull the seal and reposition it as it had been pulled down and wasnt on all the way at the top corners.
Old 09-06-2007, 06:40 PM
  #54
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by Bullwings
I've been having the gasoline smell problem too. In fact, I like the way it smells, but then again i like the way clutch and rubber smells too. Everyone else in the family complains about it though.
I have the smell in my car when it's just sitting in the garage. But, when i take it out for a drive, if i have the windows up it smells just fine. However, if the windows are down, I can smell the gasoline, and if i push the car above 3500 rpm and more into boost range the smell gets stronger. Anyone else get this?
100% same as mine. I do notice it more when the gas is below 1/4 full.
I got rid of most of it by addressing the rear hatch seal issue.
Also, mine seems more prominent if the ac is on... ???
Old 09-07-2007, 09:40 PM
  #55
LFA951
LFA951's Avatar
I usually smell like oil after driving her for a while, must be breather I have on stock AOS catch can...
Old 11-16-2007, 10:07 PM
  #56
JimBob951
JimBob951's Avatar
Mine has really started to have a bad exhaust smell inside, especially after hard accleration.. Clothes smell like I just cut the grass behind an old push mower!
Old 11-17-2007, 02:38 AM
  #57
Blueman33
Blueman33's Avatar
It's the hatch.
easy test.
take a piece of paper and cut a half inch strip.
open hatch, put paper in, close hatch.
if you can move the paper freely, there's your problem.
most likely area is by the latches
Quick Reply: Why do these cars make your clothes smell like fuel?
