Oil change results in engine tick?
oh boy.... Im starting to think I have my hands a little fuller than i wanted to.
So i just changed the oil for the first time since buying the car. the old oil was of unknown type and viscosity, but it ran fine.
I used mobil one synthetic 15w50. I know people have success with 20w50, but its going to be getting colder here, so i figured i'd go with a slightly lighter cold weight. Anyways, the problem is... when the car is very warm, after a longgg drive, i hear a faint but difinitive tick. It sounds a little like lifters, and changes slightly according to rpm.
It could be a rod bearing, but i seriously hope not. my part experience has been that rod bearings are very loud, and change with rmp.
The damned of it is, it goes away at idle. Even at startup, the car purrs like a kitten. maybe the 50w is too thick for the lifters?
just hoping to hear some opinions on this one, im wondering if the oil change had any efect. I rarely drive the car as long as i did tonight. about two hours straight, to boston and back.
20w/50 is fine for all but virtually Arctic conditions. Check the manual that comes with the car.
my oil pressure kind if dances between 2 and 3 bar... actually a little closer to 2 bar. when i give it throttle it jumps back up to 4. there is a small oil leak from the front seal.
Oh, and to make you feel better - rod knock usually doesn't go away at idle and generally gets louder as you place a load on the engine (increase throttle) at varying RPMs.
I would not describe rod knock as a ticking sound, it is more of a knocking sound, hence the term. Rod knock does get louder as the engine oil heats up though.
I agree with the above. A rod knocks and lifters tick. Also, rod bearing knock gets louder as the RPM's go up - generally. I have seen one instance when this was not the case, however. Lifters generally go down with RPM's as the oil pressure increases. I also run VR1 20w50 with no probs.
Drive-by provocation guy
