MAXhpkit - US distributor of Scivision MAF (RL Promotion)
#78
Temprarily Banned per IB
Recently some people have been having issues with paypal checkout. It won't take the credit card info if the expiration date is after 2010. I have no idea why, it'a paypal. So, I signed up for Google Checkout, and on the bottom of the Scivision order page you now have the option of using Google Checkout to process your credit card order. I hope this clears up some people's issues.
Regards,
Russell
Regards,
Russell
#80
Originally Posted by danny951
Russell, have you got the units in yet?
Regards,
Russell
#81
Hi Russell, I am interested in this Scivision kit, have you done any chips for Australian cars? I only ask because I have been told our fuel here is not as good as U.S and European stuff. I am lead to believe our 98 Ron is about as good as your 91 octane, and 98 is basically the best we can get at the pump.
#82
I have done chips for Aussies, but they have been very custom. There are chips in many cars in the states that only have 91 octane available doing fine, but I have also seen some issues with cars in Arizona where they have a high ethanol blend, so it's hard to say. But the way I work is if the chip you get is not right for you car/environment, then I'll gladly send you another. If you have a wideband and can log and provide some basic feedback on how the chip works with your fuel I can certainly compensate for it. I really don't recommend using the FQS for the timing retard because it scales back timing across the board and kills your low end power. Yes, 2 degrees makes a noticable difference. If your gas is really low quality, I can adjust your fuel/timing so that the car will run properly there without the sacrifice of low end torque, and won't send your EGTs through the roof under boost.
Regards,
Russell
#83
Thanks Russell,
I don't have a wideband, I have found out our cars are running rich at dyno days, but I guess thats better than being lean! We have one fuel here with 10% ethanol, but I stay away from it. I imagine a chip designed for 91-94 octane fuel to run 15-16psi would be a good starting place. Do you have the Scivision MAF's in stock now?
Regards,
Wayne
Regards,
Wayne
#84
The Scivision MAFs were sent to me last week, I expect them any day now.
Indeed, running a bit rich is better than running lean, but if you're running really rich (10's or below) for an extended period of time you'll eventually score your cylinders. A proper AFR is best. I shoot for 11.5-11.8 under boost. Prior to boost it can climb to 12.5, that will actually help spoolup with the proper timing. But once boost begins, nothing over 12.0.
Regards,
Russell
Regards,
Russell
#85
With the other Aussie chips you have done, have any of those started off running rich initially? Yes mine and a friends cars are in the high 10's with other US designed chips.
#86
the kit looks good. I've been on the lookout for an easy MAF solution. This looks like the ticket with the chips. As i understand you do not do trade ins on chips? Also, where abouts are you located, b/c if i could go down there and get the kit i could dodge some hefty taxes.
#88
the kit looks good. I've been on the lookout for an easy MAF solution. This looks like the ticket with the chips. As i understand you do not do trade ins on chips? Also, where abouts are you located, b/c if i could go down there and get the kit i could dodge some hefty taxes. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Regards,
Russell
