Calling out Special Tool, 1/4 mile race
#391
Drive-by provocation guy
Originally Posted by special tool
I don't know what to say to this?
Are you asking me a question?
2 bar is almost exactly 29 psi.
Well, half busting your ***** and half legit question.
I just know you are all about quick spool/broad tq. curve so I was a little suprised to see you making peak tq at 6K.
Still bad *** numbers, I just assumed you had peak tq. around 4-5K or something.
#394
yes - no more head lift whatsoever.
#395
Hi use this on his engine
http://customengineeredperformance.com/services.html
Pertty cool.
regards,
AL
Pertty cool.
regards,
AL
#396
Originally Posted by Corleone
What have you done to prevent that? Other headstuds? Glued headgasket? Heavy clamp? O-rings? Low ignition?
#397
Monkeys Removed by Request
560 on pump is very strong. Its more than I ever thought you would get on pump gas. I was figuring around 500 or maybe high 400's.
those are some strong numbers indeed. If you are pull 560 on pump then there is no question you will pull alot more on race fuel. Are you gonna advance the timming at all or just increase the boost pressure?
#398
#399
#401
Rocket Scientist
Sally.
#402
Originally Posted by toddk911
avitar????????? ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
#404
Originally Posted by DDP
Run over 30psi, then we'll talk.
Sally.
Sally.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#405
Rocket Scientist
Originally Posted by billindenver
Don't forget it needs to do that for 30 minute sessions, 5 times a day on the track...then we'll talk. ![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
