Calling out Special Tool, 1/4 mile race
Old 06-20-2007, 02:31 AM
  #196
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
im sorry trap speed is all about one thing hp and weight. Luis to say any different is crazy. Sure you need to hook but, once you do power is power. doesn't matter what its in. I've been around powerful cars all my life and driven my share....even at the track yes.
I stand by my comment depending on how close to sea level he is ....even if his ET is **** cause of his 60ft if track prep is good...his car will do 130mph in its sleep.
600rwhp in a 3500lb car isint like 600rwhp in a 2500lb car. I hope the track prep is good and he doesn't have any problem hook on the late end of the track(if they don't keep it up thats what heppens with larger hp cars...they get off the line okay then in the upper gears slip and slide down the back end of the track).
If all is as it should be. There really isint a debate here. Power to weight ratio is power to weight ratio. ST's car here running at ennis would kill.
regardless just get it on video.
Old 06-20-2007, 02:35 AM
  #197
lart951
Basic Sponsor
lart951's Avatar
Originally Posted by NZ951
All good points, missing one critical one though... reaction time
Bingo, I am not trying to start crap in here, but I once dodged a bullet.
Old 06-20-2007, 02:41 AM
  #198
pole position
pole position's Avatar
Because you draw faster than any of the Three Amigos or the big bad German.........
Old 06-20-2007, 02:48 AM
  #199
porshhhh951
To anyone actually doubting 130+ traps here a scarey accurate calculator
http://www.rx7.com/accel_calculator.html
For fun I plugged in my car which I can back up with time slips...its scarey accurate.
My car weighed in at 3047lbs and has a turbo S tranny. I ran a 14.01 @ 99mph and a 14.1@100mph Check out what the calulator said I would run.
230rwhp(I was running LBE and 14psi) weight=3047lbs shifts=4 tire height = 26inch Gear= 3.38
E.T= 13.96
Trap speed=100.91
Trap Rpm=4412
Just using tools current numbers( I don't know his weight so I put in 2500lbs)
Acceleration Calculator
Horsepower (HP) Weight (lbs) Shifts Tire height (inch.) Gear
546 2500 4 26 3.38
Power to Weight Ratio: 4.6
E.T.: 10.24
Trap Speed: 142.57
Trap RPM:6233
Old 06-20-2007, 02:59 AM
  #200
lart951
Basic Sponsor
lart951's Avatar
You freaking guys are tempting me to lower myself and go to the drag strip.
Old 06-20-2007, 04:07 AM
  #201
RPHARRIS
RPHARRIS's Avatar
Originally Posted by A.Wayne
A stick axle ! well they did use them to cross the praires and i have never seen a chariot race without one ... so you might have something there ....
I was surprised too when I saw that they were doing this but it does make sense. Some of those cars were putting down an HONEST 600+ RWHP. Now since you seem so skeptical, I would love to hear why you think semi-trailing arms are so wonderful/superior? ...ride quality and unsprung weight are all I can think of.
btw I have seen pictures of a dedicated 944 turbo drag car. I think it had a blown small block. I believe it also had a stick axel and a powerglide.
So what does this all mean for these two guys and the 1/4 mile? ...not a whole lot haha. But they should be a blast to run and especially to watch. If they really rail on these cars it's going to be some crazy squirly racing.
Old 06-20-2007, 04:49 AM
  #202
DFASTEST951
DFASTEST951's Avatar
Well, I just bought a transmission today. If I get it rebuilt with the gears I want and put in the car, I'm seriously going to try to come out there to run with you guys as I may be sending my car out that way for upgrades anyway. Too bad it wasn't just a bit later, I'd for sure make it, but if I can, I'm in...
Old 06-20-2007, 05:00 AM
  #203
333pg333
333pg333's Avatar
Joe, I thought you were going for top speed gearing not acceleration?
Old 06-20-2007, 05:12 AM
  #204
DFASTEST951
I only want to switch sixth gear for the top speed. Otherwise I want to haul *** as fast as possible through every gear with minimal wheelspin. Optimally, if I have enough power, I'd like to get 0-60 times using only first gear (like the Z06 Vette) unless it would take too long to build boost.
Old 06-20-2007, 11:57 AM
  #205
RolexNJ
RolexNJ's Avatar
This should be an interesting event, and I thought the Soprano's ending was entertaining!
Old 06-20-2007, 12:01 PM
  #206
special tool
special tool's Avatar
where you been?
Old 06-20-2007, 12:06 PM
  #207
RolexNJ
RolexNJ's Avatar
Originally Posted by special tool
where you been?
First, I had "lunch at Tony's", and I've been In Italy with the fellow Pisanos. Anyway, I will meet you guys up there for this event. I can't wait to see this, it should be really fun.
Old 06-20-2007, 12:09 PM
  #208
special tool
Dude - cut the BS - Irish guys aren't allowed in Italy.
Old 06-20-2007, 05:45 PM
  #209
TRP951
TRP951's Avatar
welcome back rolex
Old 06-20-2007, 07:22 PM
  #210
420WHP944
420WHP944's Avatar
Yes we are ! - The only problem Italians have with us Irish is that we make em look like little sissy's when it comes to beer drinking
Quick Reply: Calling out Special Tool, 1/4 mile race
