Belt squeal... then no AC
Over the weekend I was pulling away from a stoplight, got into second gear, was stretching the legs a bit after about 5 minutes from a start. -Probably got up to about 3,500RPM when there was a sudden, loud, sustained belt squeal. My car's never squealed before...
I dipped the clutch and let the revs drop down and the squealing stopped. -okay, I thought... no biggie. -I'll check the pulleys and belt tensions some time.
Then about a imute later I noticed that the A/C was not working. This is Florida heading into summer. -Non-working A/C is not an option!
I took a peep under the hood to see how buried the belts are, and it doesn't look like the work of a moment.
-Anyone think of a reason why I'd hear a squeal and then have no A/C? -Surely if the compressor siezed, the squeal would have been continuos, even after I dropped the revs to idle. -I can romp on teh revs now and there's no squeal... in fact it seems like the comrpessor isn't even kicking in any more.
Huh... -I'm stumped! -This is still an R-12 system, and I have plenty of refrigerant stored away for a rainy day, if it comes to that.
Oh yeah, this is an 89 (S-spec) with no engine mods except for an autothority chip... 220,000 miles and in top-notch condition otherwise.
Keith
Keith
It sounds like he didn't actually look at the belt because its hard to find if the stock airbox is still there. If this is true, the belt may not even be there. Check yor voltage rading on the dash while running with the blower and lights on, if it reads low then either the belt or compressor could have seized and the belt may have snapped. If the reading is normal however, then I agree with john that the A/C clutch might have gone, but if its the original comp after 220,000mi, then the bearings in the comp itself may have just quit and seized. The clutch won't engage if a problem or low freon is detected so it may have realized something was up and now it wont engage and the pulley just spins freely. Good Luck
I had same problem with my giffith a/c conversion. Clutch is lubed to spec and we just put a new belt on. Then the damn squealing persisted. so we called them and they said to make sure the belt of really tight. it still does it off and on....very embarassing to be riding in a nice 951 with a squealing belt.
Yes, belly pan is on. Alternator appears to be charging (no warning lights anyhow).
I'll have to have a close look. -My goodness, it's crowded in there!!! (stock airbox etc.)
Keith
Keith
if the alt is charging then you haven't snapped the belt, and since you no longer have A/C its obviously something to do with the compressor (actual comp or clutch)
The alternator warning light won't come on for a little while, until the battery gets good and low. At least mine doesn't.
Check the voltmeter with the engine running, less than 12 = no alternator as well = tossed belt.
If the belt is still on there, most likely your compressor clutch gave up. You shouldn't need to evacuate/recharge the system, since IIRC the clutch can be changed with the compressor in the car.
Originally Posted by RKD in OKC
When my compressor clutch went the snowflake button made a great kill switch.
Didn't get to look properly last night, but I do see a belt with "continental" printed on it, running horizontally under the airbox...
Keith
