Cam tower replacement question
Old 05-16-2007, 10:04 PM
Loquat15
Loquat15's Avatar
Default Cam tower replacement question
So im a douche and broke my cam housing... yeah, physically feel that all the bolts are out guys... your eyes can deceive you...
I have a spare cam + housing... its off a 1984 944 (naturally aspirated of course...)
will the housing work with the 86 951? If that works, what about the cam? I plan on taking it apart anyways... but... anyone know?
Thanks! :-)
Old 05-16-2007, 10:07 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
housing will work, cam is different. easy(ish) to pull the cam out of the housing, and put it in the 944 housing.
Old 05-16-2007, 10:10 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
For the record, i believe the early NA cams are the same as the 951.
But use the 951 just incase.
Old 05-16-2007, 10:42 PM
Matt Sheppard
Matt Sheppard's Avatar
Hos is right - exact same cam - dont bother with a switch.
Old 05-16-2007, 10:59 PM
Loquat15
Loquat15's Avatar
Oh, i forgot to toss this in...
The old cam came off an engine that seized due to lack of lubrication (ran out of oil)
Im taking the cam housing apart, will inspect and maybe replace the bearrings before i install the turbo cam.
Thanks for the input guys! :-)
Old 05-16-2007, 11:03 PM
Loquat15
Loquat15's Avatar
Another quick question for whoever looks at this thread...
Is a 1988 turbo S cam the same as the 1986 Cam? I found one on ebay... i'd rather go with something that has a definant quality rather than the one i have that came off a seized engine and also sat outside for a month or so (endured some rain, never thought i'd break this part...)
Old 05-16-2007, 11:11 PM
Cosmatics951
Cosmatics951's Avatar
I have to ask how did this housing actually break? Inquiring minds want to know.
Old 05-16-2007, 11:15 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Hmmm... cam towers are a dime a dozen -- might want to wait for one without a history... if not, check the lifter bores and the cam "bearing" bores, and use known good lifters and cam. Your cam and lifters should be fine even if the tower cracked, right?
Old 05-16-2007, 11:58 PM
Loquat15
Loquat15's Avatar
cam tower broke because i thought i had removed all the bolts... i looked and didnt see any... i need thicker glasses.. i missed one... a friend of mine was prying on it... i said screw it and told him to get it off and.... well it came off.
Thats how it broke.
I think i'll just buy a new cam tower... just need to know what will work!
Found a cam tower off a 1988 turbo S... is the turbo s cam the same as an 86 turbo?
Loquat15
Loquat15's Avatar
Cam and lifters are fine (from broken cam tower)
Old 05-17-2007, 01:20 AM
Matt Sheppard
Yeah, the oil-starved cam and housing is prob. a bad idea. Anytime an engine is run w/out oil, you have to figure all the bearing areas have a strong potential to be gauled and therefore useless.
Yes all turbo cams are the same year to year as well as = to early NA cams. Same part #.
Old 05-17-2007, 01:46 AM
Mighty Shilling
Wax On, Wax Off
Bastard! that's the one I'm looking at buying! let the bidding war begin...
Old 05-17-2007, 02:22 AM
hosrom_951
hosrom_951's Avatar
Cam housing for all 8v 944's are the same.
Maybe even 928's, but the lifter bores are different (i guess).
Old 05-17-2007, 03:18 AM
Keithr726
Keithr726's Avatar
Welcome to the norcal rennlist group newbie.
Old 05-17-2007, 04:28 AM
Zero10
Zero10's Avatar
928 cam housing has the wrong numbers stamped on the top
Seriously though, skip on the rained-on cam with no oil. That is asking for trouble down the road.
I have to pull my cam tower soon, and I plan to replace a couple of collapsed lifters while I'm in there.
Cam towers with cams are cheap as mentioned above, less than $50 should get you back in business.
Early NA cams are the same as turbo cams, late NA cams have more exhaust lift (or is it duration?).
I put a late NA cam into my 951 hoping to cut down my spool-up time some, but my headers are cracked so badly it is impossible to tell. Certainly no worse for the wear though
Quick Reply: Cam tower replacement question
