Rear Coilovers: Who made these & whats wrong with them???
resident n00b
I converted the suspension over to a used Huntley / Bilstein setup I bought on evilbay.
The fronts work great & look like Bilsteins.
The Rears do not look like Bilsteins and the ride height is very low
I deleted the rear tosion bars.
Mounted the coils inverted w/ Racers Edge Shock mounts.
These coilovers have height adjustment & a 16 position dampening control ****.
Springs are 0800/225/0600 Eibach Springs with <500 miles (8" x 2.25" x 600lbs)
The Height is adjusted (compressed) for the highest ride height.
When i hit full boost (12psi) the rear still squats. (with between 300-350hp) but i have to play with the dampening control.
Who makes theses shocks?
What can i do to prevent the low ride????
Did the previous user run these w/ torsion helpers?
-Jake
& Thanks to GUNS951 for the awesome deal he gave me on these rims, they look frickin' great.......
![nono](https://rennlist.com/forums/graemlins/nono.gif)
-Jake
they look like the QA1 shocks that i have. 12 way adjustable- they sell them on Jegs.com - work pretty good but not the quality of KONI etc. - longer springs, adjust them up.
resident n00b
Originally Posted by sharky47
How much did that cost you?
Struts, Coilovers & ground control camber plates.
resident n00b
How did i do?
I believe Huntley used to use Carrera coilovers. In 2004, QA1 bought Carrera.
resident n00b
Yes, i was just on QA1's site they also host on the site carrerashocks.com
So i think you are right ken.
I'll give QA1 a call and see about longer spring sizes or spacers
Thanks guys.
Thanks guys.
resident n00b
Does anyone know how these socks perform compare to similarly priced shocks like the bilstein escort cups?
Instead of jerryrigging these shocks to work it may be easier to just buy the bilsteins...
