turbo failure
Originally Posted by 2bridges
Hey Nize - what a mess, that will take some cleanup!
rebuild may be an option. I have a local deisel specialist shop that has rebuild numerous turbos for me. When I contacted them on KKK rebuild was told about $325.
May want to check your local diesel shops if rebuild is a consideration.
Originally Posted by mwc951
Several K27/6's for sale on the list lately.
okay now i'm worried, as i've found the motor has apparantly hydro-locked due to the cylinders being filled with oil. however, this occurred after shutdown, or around 500rpm, when i first noticed the motor starting to stall.
i'm wondering if anyone might be able to tell me wether i should be worried about the rods or not. i did try to start it twice after it was hydro-locked, each time the starter would 'click' but not turn which made me suspect what was going on.
is the starter motor on the 951 strong enough to damage the rods if the pistons are hydro-locked? or would the starter break before rod damage?
here are some pics of the intake ports;
what would turning it over with plugs removed prove? that the motor turns? i'm pretty sure it turns. the bigger concern is that if there is damage, i'm afraid that turning it over will cause more damage at this point.
i'm working on removing the head. i know for sure that the headgasket is blown, as oil has started seeping out the sides.
i'm just wondering if i should be thinking about taking the bottom of the motor apart as well, or if i would be okay with just replacing the headgasket and turbo.
Hey Man
perhaps i'm misunderstanding hydro-lock situations. if oil is poured down the intake and completely fills the cylinder when the intake valve opens, the piston will then try to compress all that oil on the compression stroke, and will not be able to, i thought this was what a hydro-lock situation is.
removing the spark plugs will alleviate the 'lock' so the motor will be able to turn again, but the damage (if any) would have already been done.
am i missing something?
Hey Man
Usually damage from hydroloc is from a catastrophic HG failure filling the cylinder very rapidly with water or from heat expansion in the cooling system after shutdown. The chances of a cylinder filling with oil from a blown turbo seal is very remote as oil can only enter when the engine is running. It would have to fill incredibly fast from a source not even remotely close to the intake valve. I doubt the oil supply to the turbo could ever provide enough volume to do it beween strokes. So again, what damage could have been done other than fouling the entire intake/exhaust track? If the engine starting acting up when the turbo seal failed it was probably because the plugs quit firing very quickly under those Exxon Valdez conditions.
Peter,
You should go with the Vitesse Stage 2, he may still have one at the old price. That would turn your car into a monster. I too doubt the starter develops enough torque to bend a rod.
Lou
Lou
Wax On, Wax Off
if it were me, I'd check for hydro lock when you have the head off.. that too scares me. it may have started stalling out at low RPM from when oil was entering the cylinders and fouling the spark plugs...
I wonder if oil ruined the starter solenoid and that is why it just clicks. I like the idea of pulling the plugs with a towel over the plug holes and see if it turns over. That is what we did to clear the cylinders on the Mudtang you saw at my house the other day. We even used the starter to drive it in the garage with the plugs out, no sweat.
Lou
Lou
Wow, I was under the impression that rebuilds are a
motor has never been rebuilt.
Originally Posted by spammajamma
must after 150,000 mile or so, I've seen cars listed that had rebuilds at 60,000 miles or so..I guess I got the wrong impression
if a 951 motor had to be rebuilt after 60k miles, or even 150k miles, that tells me the owner isn't taking proper care of the car, or is modding the car without doing their homework.
Originally Posted by ibkevin
What does the turbo's drain line look like?
