Supra MKIV Aerotop V8 turbo project
#78
List of parts I can remember to date, some bling some for conversion
TRD 320kph Speedo
TRD gear ****
TRD oil cap
Momo Corse steering wheel
Momo 18" rims
Momo alloy pedals
R154 Supra turbo 5 speed gearbox
Custom shifter extension to place correctly in the tunnel
SS fuel lines with XRP nickel finished fittings
SS clutch bleed line in engine bay
Quarter master 7.25" twin ceramic metallic plate clutch
Quarter master hyraulic release bearing with XRP nickel finished fittings and SS lines
Custom spun bearing shims and spacer for clutch
Custom flywheel circa 7.25' diamater (flex plate kept to be driven by the starter under the intake manifold)
Manual clutch pedal box and master cylinder (car was auto trans converted to manual)
Custom cast bellhousing
Manual rev counter
1UZ FE 4.0 all alloy Toyota V8
Link Plus G3 ECU
Custom loom
All the maintenance parts, belts, ignition, water pump etc
Vertex twin dry cell batteries
Twin electric fans
EVO 510cc injectors X 8
Shockproof fluids in diff and gearbox
Custom drive shaft
3.5" exhaust with custom hand rolled resonator and muffler
Custom water pipes
Tein SS adjustable suspension
Carbon hood struts
Mostly de-loomed
Powder coat lots of stuff
Heads currently away being ported in my mates garage Had them on the flow bench some good gains to be had. See video on my You Tube account.
TRD 320kph Speedo
TRD gear ****
TRD oil cap
Momo 18" rims
Momo alloy pedals
Manual rev counter
Link Plus G3 ECU
Custom loom
Twin electric fans
Custom drive shaft
Custom water pipes
Carbon hood struts
Mostly de-loomed
#79
Looks awesome Andrew. Curious as to the size of your exhaust as I thought it was you saying that there is evidence that over 450whp we should be using 4" or even 5" if my memory serves me correctly??
#80
Its really a matter of back pressure not capability. Of course you can make over 450WHP with a 4' exhaust, I have seen a mate make 750WHP on his straight through 4". At 4" Mr Edgar found 375Kw was acheivable with less that 2psi back pressure. Its really about trying to minimise losses where you can in my opinion. Im running the 3.5" system while NA, and will keep it when turbo charged but run a seperate system for the wastegate... like I did with my 944. I found a 6psi pressure drop in the exhaust when I ran a seperate WG system, from just over 6psi to just under 1psi. Depending on the size I go for the effective size of the total system will be brought up to circa 4.25"-4.5". Im really trying to make 500-600WHP with as little boost as possible Hoping for under a bar, and with the exhaust I have planned I should be able to do that with less than 2psi back pressure in the system post turbo.
#81
So in your opinion a turbo motor running say, 600-700 tq/hp could happily live with a partial 5" exhaust?
#82
What do you mean by partial? A stepped exhaust to 5"? Certainly capable, not sure on the kind of back pressure contaminating the combustion though.
Well I have seen a car with a smaller exhaust make more, so I guess you could say happily live, I havent seen back pressure readings from it though. It really does rob HP from what I have read... Edgar did some testing on this and found even a small amount of back pressure (at least what we might consider small, circa 7% IIRC), had a huge impact on power.
#84
you could put another engine in that free space infront of engine
beautyfull supra
beautyfull supra
#85
See, I have this friend...
#86
(Cue voice of Russian femme fatale. Seinfeld ep#) Tell us more of this Edgar??
#89
well more inportantly he was the editor and writer of Zoom magazine in it's first ten years when it was cool . he did projects like fooling the latteral acceleromers in the R32 gtr for a in cabin ajustable front rear torque split. All his brilliant work can be found at autospeed.com.
he is the greatist automotive journo to ever live I'll try to leave it at that but i can go on if you like.
#90
^^ No that's ok. I think it's time you attend your shrine to him lol
Sounds like an interesting guy. I get Autospeed so I'll check him out. Didn't know his name.
