Damned intake gaskets!
Old 03-22-2007, 07:07 PM
bigred1001
bigred1001's Avatar
Default Damned intake gaskets!
I don't see how you can get these baked on things off without being fairly aggressive. I am using a scraper tool and have not left any gouges, but certainly some fine scratch marks. Anyone know of a good chemical to use to loosen them up?
Old 03-22-2007, 07:27 PM
billthe3
billthe3's Avatar
Interesting that you're having problems. Mine all popped/fell off when I pulled the intake.
I would assume that any scratches or gouges left by the scraper would cause no issue as the gaskets are there to fill in any imperfections in the mating surfaces.
Old 03-22-2007, 07:41 PM
Bri Bro
Bri Bro's Avatar
Some sealant must have been used, mine always come right off. Use some brake cleaner and a single edged razor blade.
Old 03-22-2007, 07:55 PM
cruise98
cruise98's Avatar
paint stripper works too. make sure it is safe for aluminum.
Old 03-22-2007, 08:20 PM
Van
Van's Avatar
+1 -- use a brand new single edge razor blade (not the one that you've been using to open UPS packages for the last two years...)
Old 03-22-2007, 09:53 PM
Rock
Lazer Beam Shooter
Rock's Avatar
As long as youre not stabbing the **** out of it, I dont think fairly light scratches here would cause trouble. Once you torque the intake down, that gasket squishes all over the place.
Old 03-22-2007, 10:13 PM
bigred1001
bigred1001's Avatar
That's what I am hoping. I went out and bought permatex gasket remover and am now spraying, waiting, and scraping. Repeat, Repeat, ect. Its a slow process. Here are some before/current pics
Old 03-22-2007, 11:01 PM
caster951
caster951's Avatar
Take this time to delete the venturi and replace all of the hoses under the intake. You will be happy you did! You can do a search for info on the venturi delete.
Old 03-22-2007, 11:05 PM
Bri Bro
Bri Bro's Avatar
And the rear heater control valve and attached water hoses.
Old 03-22-2007, 11:09 PM
David Floyd
David Floyd's Avatar
A light coat of grease on the new intake gaskets and you won't have removal problems again.
Old 03-22-2007, 11:34 PM
bigred1001
bigred1001's Avatar
Which device is the heater control valve? Also, would anti sieze work as the "grease" to prevent the sticky gaskets in the future?
Old 03-23-2007, 12:06 AM
Bri Bro
Bri Bro's Avatar
Heater Control valve. http://www.944online.com/cgi-bin/ASI...ystem-944turbo
Grease works but I bet if you put it on without any sealer, it will come right off next time...they come off that easy.
Old 03-23-2007, 02:07 AM
bigred1001
bigred1001's Avatar
Does the coolant need to be drained to replace the valve and heater hoses?
Old 03-23-2007, 02:12 AM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
yes. yes it does.
Old 03-23-2007, 02:35 AM
jmporsche944
jmporsche944's Avatar
Been there done that man, sucks, but theres not great way to do it. My valve cover gasket was the same way.
Quick Reply: Damned intake gaskets!
