v8 ls1 vs vitesse stage 1
#61
I agree lart, the guy with the smaller powerband will have to shift more and work at it to get the results out of his car. And yes, an ls1 will be cheaper and more reliable.
I personally would never have a v8 unless it was in a Corvette or something like that.. But as lart said, that's just personal preference.
Very interesting thread!
EDIT: I take back my statement about never having a v8 unless it was in a corvette.. I might consider doing something like what Mike is doing with his LS1/80's bmw 5-series! One can try and compare the performance per dollar, but in the end it just comes down to what you would enjoy the most.
#63
Originally Posted by porshhhh951
those are some clean ls install's.
I would like to have a ls7 in my 951. Then I could just do some simple mods and enjoy 135-140 traps.
#64
Originally Posted by VRSTAGE2
More of Pat's car
#65
From: San Francisco, CA Porsche: '92 968 Blk/Cashmere
Also, an NA car is going to be more easily throttle steered thru the corners when the engine is usually going to be in a relatively lower rpm range.
#66
#67
Originally Posted by RolexNJ
And prior to that is trail-braking. After you do your braking, let alone, threshold braking hard, you can come into that turn having confidence with a N/A, that after you trail-brake the RPMs will be their sooner and you can throttle steer thru the turn as you said. This is the on-going challenge turbo people have as we know. Good point Chris!
They do make these things called superchargers...
#68
#70
anyone have a breakdown of the actual costs to do the ls1 into a 944? it seems MUCH higher than simply modifying a turbo by looking at the numbers on renagade hybrid's site:
$2,100 Complete LS-1 kit for 924S, 944, 951 and 968 Porsches, hardware and instructions. For design and application purposes, parts will not be sold separately. (does this really have EVERYTHING I need to drive away with a ls1 in my 944na? just the existance of a large optional parts list makes me think that it doesnt really have all that's needed)
plus optional parts - what do I need here??????
plus the engine $2500-$15k
total is UKNOWN but anywhere from $4.6k to $17k and up
this is where I'm looking for costs
both cases need a new 951 trans, maybe a new clutch, maybe new brakes but not really since I'm on the street only....
anyone with actual experience and numbers?
this is where I'm looking for actual costs for a nice sporty street 944
do it the turbo way
from broadfoot racing:
1987 through 1995 944S, 944S2, 968 16 valve engines $4,200 (add $1,200 to R&R and Tune) (I'd have it be done with strong studs and forged everything and metal gasket and low compression, maybe lightened crank)
add turbo parts and vitesse kit/LR kit/exhaust $3k max (combination of used parts when possible)
total for turbo route is about $7.5k
do it the turbo way
#71
Drive-by provocation guy
Originally Posted by sweanders
Yup, more torque up until the moment the turbo spools. Ever compared dyno plots on a 951 and any N/A engine?
Turbo any day for me.
V8 = low end grunt and that's it. It runs out of steam way to fast.
Are you, those that do the conversion, looking for the "feel" of a low end car or do you want the best performing car? to inlcude 0-60, 1/4 performance?? I would assume straightline accel is a major factor if one is putting a V8 in their car.
Because 10-15K to have a smile on your face for 4 seconds from a redlight seems very expensive due to the fact that at 5 seconds you will see a VR tuned 951 come screaming past you.
My car is not even at VR levels of spool up (kind of laggy) and I can't tell you how many V8's I have driven around; even in low end/speed races.....much to their dissapointment.
Of course, to each his own.
#72
Just another thing I like about my "too big" of a turbo in that it is very linear, at least in the spool up. I get pressed back into my seat, but not a sudden onslaught of boost
Which I agree at the track is NOT what you want coming out of a corner. Although that style of exit from a corner sure makes for some cool video clips
#73
Originally Posted by toddk911
+1
The question for me is which is cheaper and easier to put in a 944na that I bought for $550.
My choices are:
1) ls1 transplant (lots of work)
2) 2.5 or 3.0 944 turbo transplant (fit's just right)
3) 2.5 or 3.0 944 turbo engine but with a kenne bell/whipple (twin screw) type super charger (fits just right, but need to make a custom intake and mount and expiriment with the amount of boost to get 400rwhp)
#74
http://hostbandit.com cheap web hosting
I dont want to turn this into a turbo vs supercharger debate but this is very interesting:
The revolutionary new W210ax compressor has the ability to run nearly 30lbs of boost (engine modifications required) for unheralded performance.
Whipple Features:
INSTANT BOOST / HORSEPOWER & TORQUE AT ANY RPM
* Over 100rwhp gain with 15psi and custom tune.
* Over 200rwhp gain with 19psi, custom tune, Ford Racing headers and cat-back exhaust.
* Over 40hp gain at stock boost levels due to lower parasitic losses.
* Over 40deg F cooler air at 15psi allows for more spark advance and more power.
* Direct bolt on replacement.
* Lower noise level.
* More power, cooler charge air temp, less power consumption/parasitic loss than stock Lysholm 2.3 liter.
* 3.4 liter vs. 2.3 liter compressor for more power potential.
* Up to 95% efficiency.
* Boost range 15 - 30 psi with SC pulley changes.
* 4 bolts to remove SC pulley, no need to pull SC off for pulley.
* Included adjustable idler pulley for extra belt adjustment.
* Internally lubricated.
Whipple Features:
#75
What about a turbo that is more linerar in it's spooling and not a "instant on" turbo? Just another thing I like about my "too big" of a turbo in that it is very linear, at least in the spool up. I get pressed back into my seat, but not a sudden onslaught of boost. Which I agree at the track is NOT what you want coming out of a corner. Although that style of exit from a corner sure makes for some cool video clips.
Sorry for the OT, back to the program....
