Wastegate question
I have a fairly stock 1987 951 that I am thinking about doing some more mods to. At this point the car has an Autothority MAF kit and aftermarket chips (I think Autothority as well), but nothing else that I know of. I have a friend that is a tial dealer and I can get a good deal on a tial wastegate through him.
What size wastegate should I be looking at that would allow me to go to a bigger turbo later on but would still work properly with what I have?
Should I consider a manual boost controller if I do the aftermarket wastegate? What about AFR monitoring?
I'm pretty new to the 951 scene, so please bear with my ignorance. My friend also builds custom stainless steel exhaust systems for 911 & 930's, so hopefully once he gets caught up on some other projects he may prototype a new 951 system using my car!
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Originally Posted by ryanm6100
So does this mean your friend can get ME a deal on a Tial???
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Tial 38 seems to be the most recommended WG for the 951, some use the larger one with the bigger turbos.
Speedforce racing makes and adapter for the tial for direct bolt on.
Cast Iron Man
I'm going to put in a plug for the Lindsey Racing dual port wastegate. I do believe the Tial is a quality piece but I liked how the Lindsey unit was a direct bolt up in place of stock. No adaptor plates and it uses the stock mounting hardware already in place.
Thanks for the input guys. I could possibly check to see if I could get him to do a group buy for tial wastegates if there is any interest. I suppose we would need to clear it with admin first. I will check to see if he would be able/willing to do something like this first see if we can get permission to post a group buy thread from admin.
FWIW, I like the idea of a straight bolt-in like the lindsey dual port setup. I may just be able to get a much better price on the tial, enough possibly to make it worth the extra work to set that up.
Philcav7, thanks for the heads up on the adapter.
An EBC is well worth the extra money. Mechanical controllers are fine unless you want to run high boost levels and push the limits. For that, they suck royally and are not up to the task of precision control required. If you're not going to "walk the line" however, you should be fine with what you're proposing.
Keep the black **** out of the cockpit. Having it within reach of the driver is a bad idea.
Tials seem to be more-or-less the industry standard for wastegates, although installation is not particularly easy on these cars unless you do your homework first.
Anyone aware whether there is an adapter for the Delta DP wastegate for direct bolt on? The WG came with the car but I really don't like the creative engineering to make it fit.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
For now, I just want to make the car a little bit quicker so I can pass my buddies 911's on the straights!
Rennlist Lifetime Member
Originally Posted by reno808
They are so well made that you need to mod anything. The only thing is they fit only a certain way. but its WELL worth it. TRUST ME. Anyone here can say the same thing. the diff is NIGHT and DAY
I'm interested in the clubgate for my race car since it's approved for PCA stock classes.
Thanks,
Rick
Originally Posted by Rick
What is the difference between their dual port and their clubgate? Is it just the fact that the clubgate vents and has a softer spring than the dual port?
Thanks,
Rick
Thanks,
Rick
