UK 3.2 Turbo hits the road
#166
Originally Posted by DivineE
I just needed to post here because this smiley describes my current state of anticipation! (psssst Paul has been to the dyno today... )
#169
Dont get too excited.... Low boost, a running in map, lots of stock bits holding the engine back.... Its the torque and where the torque happens that is the interesting part.
Also remember that this rolling road is a DynoDynamics dyno... Known as the "rollers of truth" because its consistant.... Its also the lowest reading Dyno in the UK, which is why its chosen for the UK 944 turbo league table, as its not an optimistic dyno, its a low reading and repeatable dyno.
I am sure Paul will be here soon to post some charts.... I am happy so far! I think Paul is too!
#170
I've seen it too
15psi!!!!!!!! Just imagine what this baby could do once its got a few 1000miles on it at its max potential of 32psi!! With the right inlet, exhaust and mapping
#173
Now I know why I've been having a few traction issues
The guys at Weltmeister spent a while dialling in my Greddy boost controller to the target 16psi that we thought would see safe AFR's with this setup, then they did a few power runs that yielded these results:
348bhp and 450 ftlbs of torque But on one of the runs they detected a bit of detonation due to the pretty standard ignition advance. AFRs were still at a very safe 11:5.1 to 12:1 range. So for safetys sake they dialled it down to 15 psi and obtained the following graph:
337bhp and 420ftlbs of torque. This is the level I will run at for the time being but I'm now so excited at the potential that is in this engine once we pay attention to the breathing. I never dreamed we would be over 400ftlb at this early stage of development (and it makes that figure before 3500rpm). I'm so looking forward to getting her out on track and getting used to the power and low down grunt with some proper sticky tyres
#176
That's an insane amount of tq for that boost level
Yes I can imagine you were experiencing some knock in the midrange. 2.5l timing is way too retarded above 5000 rpm for your engine, but at the same time too advanced in the low range.
Long time plans should at least include a proper camshaft besides engine management to flat out that tq curve a bit. Personally I'd like to see a short runner intake as well. Those things together would really flatten out the tq curve and the result would probably be one of the nicest 951-engines ever.
Sweet!
Sweet!
#177
"Why did they do the pulls in 3rd gear and not 4th?"
The dyno runs are in 3rd gear because thats what DynoDynamics recommend... possibly to cut down damage that can occure if you get a blow out on the dyno, it also puts the engine under stress for a shorter duration.
They also say its because inertia dyno's are innacurate and need 4th gear runs... But thats from a company who do not sell an inertia dyno... so you would expect them to say that.
#178
Sweet!
Sweet!
#179
Damn, so those 2 runs were really in 3rd gear?! Run it in fourth and you might be pleasantly surprised.
#180
Agreed...
My prediction is that with 18 to 20 psi of boost and a dedicated mapping, Paul's car is going to make a leap in torque and BHP.
As the car is suffering from problems laying down that torque already, some of the gained torque could be sacraficed in exchange for some more top end power to equalise the balance of torque and bhp.
If this was my car I would probably be busy planning a MAF, custom intake manifold, 3" or 4" exhaust, custom cam and possibly a prologic traction control system...
But then again thats in my fantasy 944 turbo project which is still in my head where money is no object!
In the real world, Paul needs to recover from the cost of this project and not get divorced by being careful how much he spends...... Any chance of a loan of a MAF and piggy back Mr Vitesse??? It would give a good "before and after" example of the benefits it has over an AFM for your marketing! (its worth a try I guess!)
