Exhaust manifold stripped stud leak, remedy anyone?
Today we were idling the car and my tech put on his doctor's listening device and heard a leak coming from the exhaust manifold between two studs on different headers facing each other that are apparently stripped, since they are longer than the rest and keep turning upon tightening the nut. What is the best and quickest way to remedy this kind of leak without having to remove the head??
I had this same problem on my car. I had SFR fix it when I had their stage 1 headers installed. Basically all they did was enlarge the hole for a size larger stud, then lathe half of the stud down to Porsche specs. It's help up very well on my car and I have no leaks.
-Darwin
-Darwin
Kudos to SFR, that seems like a very clever solution to a big pain in the *** of a problem. I'd think the headers have got to come off, not the head though. I could be wrong.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Give up now and accept your fate – you need to pull the head to fix it right. It’s so tight there that anything else risks getting the stud installed crooked or other damage.
So now you can replace the head gasket and fix any other leaks. See, it’s a positive thing…
I agree with chris. I have done this with the head in the car using an angular drill and tapping it but that was decades ago when I was afraid to remove a head. If I had to do this now, I wouldn't even think twice but remove the head.
Raj
Raj
Well, i'd try a helicoil before going to a bigger stud.
As a temp fix, you might get lucky and find enough good threads deeper in the hole. If so, get a long bolt (M8 1.25 I think) and cut it to length as a longer stud.
What the heck is a helicoil?? Yea any shop would want me to take the head off, it's 10 hours labor, I want to try something without taking the head off, cause we just put it on, so I'd hate to back to the drawing board...
helicoils are amazing!!!! i fixed 4 threads on my old saab carlsson head and it was like new again. I could do this without removing the head due to it's layout not sure if you'd be able though
Lazer Beam Shooter
So now you can replace the head gasket and fix any other leaks. See, it’s a positive thing…![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Best answer.
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
