high flow cat
has anyone used or researchedthis product. I know using will affect some Hp but to stop the heavy staining on my garage floor from exhaust would sure be nice!!
random technologies these are the best cats and they actually work some of the others not so good. metal cats are junk i've tried a few others flow is not so well. bottom line if you need one it should work, why is your floor staining? that's not a cat prob. contrary to popular belief a properly sized cat will not cut down on power
Small Business Partner
Proof?
Any backpressure post turbine is detrimental, period.
Rogue
that's why i said properly sized-a cat is not a restriction if properly sized i have seen most perf. mufflers flow at 475 cfm or so i saw a 3" performance cat flow at 502 where's the restriction
Take some backpressure readings, I bet you will be suprised. Its similar to taking a whole bunch of stir-straws and blowing through them, sure you can breath but not that easily.
Rogue
Rogue
i have taken a back pressure reading i have an sfr 3" with a random tech 3" cat no diff with or without cat, now the crossover pipe is a diff story if you truly need a cat a metal cat may not work they are not that effecient
i have a snap-on test gauge made for that great tool to test for cat probs unscrew 02 install adaptor connect gauge start car i used the bung on my wide-band for that hookup, to test for backpressure in the x-over i used a length of silicone hose and the same gauge
Former Vendor
Originally Posted by ian kam
pete how is it ?? Did you loose alot off performance ?? Did it change the tone of the exhaust ? Any feed back will be helpful.
I can't say if it's the cat or my turbo that causes the most of the backpressure,but it's almost two times boost at 6000rpm+.
My turbo is completely modified KKK27/6 and I get 348hp @ 5568rpm and 506Nm ( = 375lb-ft ) @ 4056rpm ( both at flywheel ).
LOL, putting a cat on a modified turbocharged car is a waste of money. While I can appreciate it's environmental benefits anyone with a chemical understanding knows that a turbocharged car provides everything required for maximum cat death.
At 300whp a nice high flow cat is maybe hindering you 2-3whp tops with about 100 - 200 RPM of spool difference. If the cat would live longer I'd probably put one on my car.
