Went back to the dyno today....
Old 12-28-2006, 10:39 AM
  #256
Porschefile
Porschefile's Avatar
Originally Posted by special tool
Well - I have decided to try the ARP's after talking to their tech.
He was semi busting my stones about running (trying) 700 HP on Porch stretch armstrong studs.
I will change NOTHING else.
So some of you guys who really want to know if these are worth a damn, or just BS, stay tuned.
I will be posting facts (as usual) with regaurd to cylinder head clamping a high HP 951.
By the way, I am sure you all know that the head is off and 100% cleaned and checked already, right?
Cool! Thanks for being the guinea pig. I didn't realize you were on stuck head studs. ARP does make great stuff, and their products have been pretty widely proven in a huge variety of motors. I guess the real question though is how much of an improvement are they over stock. ARP lists all the info you could possibly want to know on their website, regarding the metallurgic properties and various alloys used for their products. Does anyone know anything about the stock studs as far as the specific type of alloy? From what I've seen in the past, I'd tend to believe that ARP's alloys are probably superior to the oem stud's.
Oh God, considering I can remember Stretch Armstrong, am I just too young?
Old 12-28-2006, 11:02 AM
  #257
Porsche-O-Phile
Porsche-O-Phile's Avatar
Wow. . . "Stretch Armstrong". LOL!
I actually remember that. I guess I'm an old fart.
Old 12-28-2006, 11:19 AM
  #258
toddk911
Drive-by provocation guy
toddk911's Avatar
I will weld it on if I have to (seriously).
But I will exhaust all rational means first.
Just like drag cars
Old 12-28-2006, 11:22 AM
  #259
toddk911
toddk911's Avatar
So is the issue, as someone said, that this turbo just makes more boost sooner so the head had more pressue sooner???
Could you try a run with a boost setting for higher rpms to see if that helps? So with EBC have boost not go to 28psi unitl 5K or something along those lines.
Old 12-28-2006, 11:43 AM
  #260
kasturbo
kasturbo's Avatar
Is there an advantage going with the ARP's over the Raceware studs? Do both require you to retourqe after so many miles?
Old 12-28-2006, 11:46 AM
  #261
xsboost90
xsboost90's Avatar
some old porsche race cars had the heads welded on- not sure which ones though.
Old 12-28-2006, 11:51 AM
  #262
hot-J
hot-J's Avatar
How many times did you reuse the porsche studs?
Old 12-28-2006, 12:04 PM
  #263
special tool
special tool's Avatar
the old turbo did the same thing - its on my old dyno video.
The lift is worse at high revs.
Old 12-28-2006, 12:05 PM
  #264
special tool
4.
And be advised...
my engine was good up to about 500 hp with these old studs - but no more.
Old 12-28-2006, 12:54 PM
  #265
Tom M'Guinn
Tom M'Guinn's Avatar
Good move. I torque to 85 - 90 ft lbs, per Gomes. Gomes has been there and has the t-shirt.
Old 12-28-2006, 01:06 PM
  #266
toddk911
toddk911's Avatar
Once the head lifting issue is resolved, what would be the next weak link that could show itself???
Old 12-28-2006, 01:11 PM
  #267
Mark-87-951
Mark-87-951's Avatar
That's a good question. I certainly hope it isnt something more catastrophic.
Good luck! this has been very informative.
Old 12-28-2006, 01:32 PM
  #268
special tool
yes, but no dyno evidence past 500 RW.
Old 12-28-2006, 01:54 PM
  #269
Laust Pedersen
Laust Pedersen's Avatar
The vintage Bugatti had the block and head cast in one, so no messing with headgaskets, studs, nuts and assembly torque.
The MLS HG is much stiffer than the WFHG, meaning that head-gasket-block separation requires less stretching of the studs and therefore less force (combustion pressure) for the same clamping force (head nut torque).
As Tom was suggesting, I would try to get some information on max allowable head torque and target that. As I recall, I am at about 90 ft-lb with MLS and OEM studs.
Laust
Old 12-28-2006, 01:56 PM
  #270
toddk911
toddk911's Avatar
Laust
Kind of scary though as this route is like a pressure cooker with NO release valve!!! I think they also call that a grenade
Quick Reply: Went back to the dyno today....
