car back togther and it still smokes
![Thumbs down](https://rennlist.com/forums/images/icons/icon13.gif)
Finally got around to putting the plates on the car today so i could take it for a test drive. Car runs great but even after the rebuild and installing an oil resticter the SOB still smokes under boost.
At this point I am about ready to sell the damn thing as I cannot afford to throw any more money into it. Really can't understand why the thing did not smoke at all when I first installed the turbo since now it smokes even with the restrictor installed.
I really can't see me driving this thing on a regular basis if it is going to spew oil smoke out of the exhaust ever time I get on boost.
b
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
what kind of chips are you running? Also are you running a catch can? Is it routed back into the j boot or maf pipe? Make sure the AOS is routed to the j boot or maf pipe before the turbo to keep vacuum on the crankcase or your turbo wont drain right and the oil has to go somewhere
I am running Guru chips with a mafterburner to fine control the fuel. According to the wideband I am not running rich under boost. All runs were done under partial throttle.
Not running a catch can at this time. I have one but did not install it as last time it made no difference. Guess I can install tomorrow and see if it makes any difference. AOS is routed to the stock posistion on the J boot at the moment as I have yet to install the MAF.
I am a little concerned about going any smaller. I find it hard to believe that even under 60+ psi of oil pressure that a .080 hole can flow enough oil to flood the turbo instantly under partial boost.
Originally Posted by TRP951
you might want to check with SFR about the oil restrictor or i think david floyd had the same problem with his turbo a long time ago
Checked the car out againj this morning and it took me all of about 2 minutes to figure out what the problem was. All I am going to say is that it was my own stupidity! Turbo now works great. I am able to hit 17+ psi in 3rd gear at part throttle. Have not tried any full throttle runs yet as I am still trying to fine tune the part throttle maps along with burning off all the old oil that is still in the exhaust.
Originally Posted by david fracolli
In my haste to get the thing back together I had swapped the AOS line with the ISV line.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
