toluene or xylene sources???
I'm looking for a little octane boost. I'm in a small town and only have access to a Home Depot (and a couple other mom/pop hardware stores). Would I be able to find either toluene or xylene there at Home Depot, maybe under another name or something (i.e. what should I look for)? I assume this stuff would be in the paint area?
Also, I believe I read here somewhere about using one of these to boost octane will also have the side effect of burning cleaner, as in I will be able to pass smog more readily this way. Is this true??? (smog test coming up very quickly). Thanks!!
pole position - the closet 76 station to me (according to their locator) is ~90 miles and the best they have is 91 octane; closest Sunoco w/race gas is twice as far as that. I've looked into it quite a bit and the only higher octane stuff near me is leaded race gas or AV fuel. Willow Springs is also ~90 miles, so I would think I could get good gas there (track guys tell me - can I pull in and fill up my car, or are there some hoops I have to go through first, or even only for on the track???), but again, that's a long way to go for good gas.
eospeed - I will PM you.
Thanks!
Thanks!
Originally Posted by eospeed
You can have VP an many other fuels delivered to your door.I am a VP dealer an could give you a price on motorsport 103 unleaded if you like on mon.
How is it delivered? How much does one need to order to get home delivery -- and is it super-expensive to ship because of its weight and danger?
HD has Xylene. I get it in 5 gallon containers from my local paint store.
Any paint store should have xylene, including HD. It's a bit pricey, but it does work quite well. Do a search, and you'll find a couple of good formulas to help with figuring out octane.
Try motorcycle shops in your area. They sell it at the pump here in Vegas but when I travel, I just stop at any motorcycle shop and pick anywhere from 100 to 114, just make sure it's unleaded. Xylene takes a toll on your fuel lines. If you start using it, I would recommend getting steel braided lines.
Originally Posted by pole position
The stuff is usually 8 - 12 bucks a gallon, not worth it.
No race gas within 100 miles ( that I know of ) and I only want more than 93 pump a few times a year, so Xyelene for me.
