Rebirth of a racecar - project pics
#243
Rennlist Junkie Forever
Hey Skip
Nice job. I know Chris Cervelli and I'm familiar with that car from back in the day...
A couple of things...
1. Are you allowed to run an adjustable boost controller in-cockpit in your class? I'm not sure, but I didn't think you could in the GTS classes on turbo cars (helps keep you honest if you win)
2. Why are you running that wing? Is there a class restriction on the type / size of the wing such that you can't run a normal race wing? I'm asking because the difference between the 968TRS wing and a full race wing is huge.
3. With the car at 2375 wet without driver (assuming 200lbs for driver and gear) that puts you at 2575lbs race weight / 310RWHP - 8.22lbs per hp.
Running DOT R compound tires would put you in GTS5
Am I missing something here?
Hey... BTW, the car looks great. Nice job.
TonyG
TonyG
#244
4. Running DOT R compound tires would put you in GTS5
#246
You are right. Although need to add 25 lbs for the driver. But once I get the new wing, and a final weight (have a Kokeln rear suspension to add, gutted the doors as well as a couple of other small things) will do a final tune on the dyno to get just over the 8.5 limit.
You only get weighed at impound after the race.
Personally I think you'd be better off adding more weight and going to slicks. The difference is huge.
Anyway... the top couple of cars in GTS4 (the 996's which run full GT3 or cup car suspension, short gearing, and run on Hoosier slicks and full aero) kill me because I'm on R compound tires.....
TonyG
