Intercooler up grade made by Autobahn Garage in NW Ohio
#33
Originally Posted by Wolf Pack
So ther is really only one way to say if this is worth it is to hit the Dyno? Number's wont lie
WOlf PAck 88 951
WOlf PAck 88 951
Precisely, back to back and then look at the numbers...
and I don't think more flow = more power...
more flow at same pressure (not boost but IC outlet pressure) = more air AND when combined with more fuel = more power...
j.
#35
Was it flow tested Olli
#36
Originally Posted by T Tanner
In time I plan to do a dyno run side by side and post the results
#37
I have heard all the thoughts on doing the mod to the IC some say no and yet we have vendors selling the mod advertising with one vendor showing a 18% increase in flow. To me it looks like the right thing to do. So I am asking, why did Porsche design the 951 IC with what looks like a air choking end cap? From what I have read and seen on the Renn List with the people racing the car is most if not all have installed larger IC. If we install a larger IC are we not also increasing the flow and the cooling surface? Looking at the IC today it looks like to me that air will follow the least path of resistance and looking at the front of the input end cap it looks to me like the air going in will not even make it to the front side of the IC. I could see that it would look like one could slice a wedge out of the IC starting at the front side of the IC where the end caps meets up with the core. I am having trouble seeing where much air is being feed into the leading edge of the IC because where the end cap is connected to the Core ther is just not hardly any open space between the core and the end cap. Wouldnt the leading edge of the IC be the best place for air to flow where it would be getting the most out of what an IC does?
If you know the answers please show me the light on how the Porsche design is better? If changing the end cap is wrong then why is the Porsche end cap so right???
Wolf Pack 88 951
Wolf Pack 88 951
#39
If the majority of the air is moving through the front, the outside air cooling the aft tubes would be seeing warmer air. It looks to me like Porsche was trying to achieve and even and minimum temperature at the outlet end of the combustion air, at the expense of some pressure drop. As someone said, it is the temperature of the air that is important (and guards against detonation). Need it to breathe better? Turn up the boost. Increased flow accross the outside of the intercooler should be the goal of a modification of the intercooler or nose panel. That would yield more power and safety.
Lou
Lou
#40
Also, yet another variable. As ST posted, dyno's don't do an intercooled car justice. The portable fan does not produce the air flow of road speed. So a dyno run might not give a true comparison between two ICs.
Lou
Lou
#41
Wolf, Porsche designed the intercooler using very sound principles. Again, I suggest you read up on Bernoulli's theorum if you don't believe me. The limitations on the stock intercooler are based pretty much on size and surface area, not internal design. There ARE gains to be had by modifying the intercooler, but they are to be had by making the surface area bigger or by trying to reduce the ambient external temp (either by trying to direct more air through it or spraying it with a cooling agent), not by trying to increase the flow inside the existing one.
Did you notice that the narrow side of the intercooler has a slight curve to it? DO you think that they would bother engineering something like that into the product, at rather significant cost over just having a straight piece, if there were no benefit to it. Again, read up on flow dynamics if you don't want to believe me.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Regards,
Regards,
