Dyno'd the 951 today.
Old 02-16-2006, 11:00 AM
  #61
OriginalSterm
OriginalSterm's Avatar
Originally Posted by toddk911
Yes. On any older performace car you always, no matter how painfully expensive, take the "while your in there" approach. That is were a $500 parts/labor job turns into $2,000 !!!!
Dfast: how high of a fuel pressure can we run and not become a static pressure issue???
as pressure goes up, the capacity of the fuel pump goes down. the fuel pressure you can run depends somewhat on the size of the fuel pump.
Old 02-17-2006, 03:38 AM
  #62
DFASTEST951
DFASTEST951's Avatar
toddk911, I don't know the exactl limits but I've turned my fuel pressure up to 53psi but the only thing it did was not let my boost go over 1 bar (20psi).
Originalsterm, I believe you are right about needing a bigger fuel pump and I have one as well. I am upgrading to bigger injectors. How big is going to determine if I do anything else like swap out my chips, exhaust, etc.
Old 02-17-2006, 08:51 AM
  #63
OriginalSterm
1 bar is about 14.5 psi
Old 02-17-2006, 06:26 PM
  #64
DFASTEST951
!!!!!!!!!!!!!!! Holy Shiza! I just looked at the dyno it was actually 1.1 bar and I got 406 hp with my richness going off the graph at 10. It was probable at 8. Way to rich. That's pretty good hp...
Old 02-18-2006, 01:32 AM
  #65
Lance J
Lance J's Avatar
joe your crazy man. i never got to look at the boost when the car was on or i would have told you lol
Old 02-18-2006, 01:33 AM
  #66
Lance J
Lance J's Avatar
honestly with the race gas that you run your should be boosted 22 psi ask "ST"
Old 02-18-2006, 02:39 AM
  #67
FSAEracer03
TRB0 GUY
FSAEracer03's Avatar
You might want to check a little more into what injectors you have.
Old 02-18-2006, 03:18 AM
  #68
MPD47
The Carnage King
MPD47's Avatar
DFASTEST, I know you payed to have your car built, and dont spend any wrenching time on it. But your lack of knowledge of what is on your car and what it can or cannot run makes me question your sanity when playing with the little black dial. To say you're putting your engine on the line is a bit of an understatement.
Old 02-18-2006, 07:43 AM
  #69
special tool
special tool's Avatar
There is a LOT of room for improvement in Joe's setup.
He is using a triple k diesel turbo, for God's sake!!
If he ever gets a modern compressor and good management, he'll be up around 500 RWHP on pump gas - 600+ on race.
For now I would leave the boost alone, however.
Like I have told you before Joe - the past engine problems were from improper management not from bad mechanicals.
Old 02-18-2006, 07:03 PM
  #70
DFASTEST951
MPD47, I don't quite get what you're saying. Tool, I know the motor has much more potential. I'm already 500 whp but 600 sounds really good. Have to change a few things first though. Oh, and I have a hybrid kkk. It blows pretty hard and now that you mention it, do you know what cfm John's stage V blows?
Old 02-18-2006, 07:27 PM
  #71
special tool
That will make 6-700 RWHP - but it will REALLY do it.
Joe - the hybrid kKK's are nothing like the modern Garrets - not even on the same planet.
Don't let anyone who sells strictly KKK bull**** you.
Old 02-18-2006, 07:58 PM
  #72
pk951
pk951's Avatar
ImagineAuto is using kkk in 930, Kevin at Imagine says the wheels they use now are nothing like the old kkk turbos of past.
Old 02-18-2006, 08:31 PM
  #73
special tool
Yes - its common knowledge that Borg warner is making modern products.
The majority of wheels in use in 951's made by kKK, however, are the dinosaur type - like Joe's.
Old 02-18-2006, 10:15 PM
  #74
FSAEracer03
TRB0 GUY
I'm still wondering what injectors he really has. Who dyno'd your car, Joe? Was it the same people who set it up, Powerhaus?
Old 02-18-2006, 11:37 PM
  #75
ehall
ehall's Avatar
Kevin his stuff was all set up by Powerhaus. He doesn't screw around with their set up. You'd be better off asking them. Joe got it figured out. Let them do it, and go drive the **** out of it. He's a gear haed but not a wrench turner. I believe that dyno was done not too long after the car was broken in about three years ago. Think about all of the new options available now. He's looking into them all.
Quick Reply: Dyno'd the 951 today.
