Picture of WB O2 Bung Install?
Hey,
I need to have a wideband O2 sensor bung welded onto my test-pipe. I was wondering where everyone has put theirs. Does anyone have a picture of their O2 sensor bung with it installed on the pipe before the pipe was re-installed? Or maybe just circle the area on a photo where I should be thinking about putting it? Everyone does put it after the turbo, on the test-pipe right?
Thanks guys,
Matt
Thanks guys,
Matt
Mine is installed after the turbo, right where it curves down and flattens out to go back to where the "test pipe" section would be on your car.
You can see it just behind the caster block, next to the crossover pipe in that photo.
Thanks David - Thats on the test-pipe correct? Would there be any heat issues with the wideband wires running the same as your setup if I dont have the heat wrap?
Hard to tell, but the sensor is actually pointing downward, so no water collecting problem, as you can tell by the date on the picture been working for over 3 years and 30k miles.
The installation manual that came with my LM-1 says to install no more angled than 30 degrees from the top (as to try and get it to point as straight down as possible). It also has to be after the turbo, for temperature and accuracy reasons. The farther away from the turbo you go, the longer it might take for you to get a usable signal ( needs to get to a certain temp before it can kick out a usable reading ).
Originally Posted by David Floyd
Yes, on testpipe, you could put some sort of heat wrap (aluminum foil) on the wires.
Thanks guys for the info!
Matt
David, are you saying your sensor (wire end) points slightly downward? Like, at maybe 4 O' clock if you will? If this is the case, and yours obviously has worked pefectly for the past 3 years, then that leads me to beleave that it doesnt matter how the O2 sensor is mounted.
Matt
Matt
I'm wondering why no one has used the stock location? Is this because most of you need to utiliize the stock oxygen sensor as well with your wideband kits?
The O2 sensor has to be pointing down (10:00 to 2:00) to avoid getting water on the tip; it is made of a ceramic material and can crack. The stock position has too much pressure and temperature which will affect the reading. Were David Floyd shows it is the sweat spot for the installation. More info below:
https://rennlist.com/forums/showthre...light=preasure
